Leaky steering rack
Discussion in '1st Gen. Tacomas (1995-2004)' started by 423 TACO, Apr 29, 2013.
  1. Apr 29, 2013 at 11:43 AM
    423 TACO
    423 TACO [OP] Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Well my truck has developed a pretty bad leak from the steering rack. My question is there a seal I can try to replace or does it need a whole new rack? Here's a picture. Thanks for the help
  2. Apr 29, 2013 at 12:38 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I'v got the same thing goin on but my leak is pretty small.
    from what I'v read and heard from others on here replacing the rack is kinda the only way to go. Apparently a "stop leak" liquid does no good, and its only a matter of time before the thing is shot. I guess if you had the time and ability to rebuild it you could, but IIRC you cannot buy the seals on their own which is stupid if you ask me.. :/
    I'm gonna put it off for a while cause I have sooo much other shit goin on in my life right now..
    Interested to see the responses here though.
  3. Apr 29, 2013 at 12:41 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  4. Apr 29, 2013 at 12:46 PM
    TIPICOTACO
    Tyler
    nw nj
    ^thats a pretty reasonable price.
  5. Apr 29, 2013 at 12:51 PM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Thanks ill look into that. I have to add fluid every 2-3 days so it needs to be addressed soon, I kinda figured replacing the whole thing would be the best bet
  6. Apr 29, 2013 at 1:30 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Have you considered a quality reman? Here in Colorado, we can get a CVJ reman rack (OEM spec rebuilds), with inner tie rod ends, for cheaper than just the ITREs by themselves.
    http://www.cvjreman.com/RAP.php
  7. Apr 30, 2013 at 2:16 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    I bought a reman. one. It is put back to OEM specs and comes with inner tierods. I also put new outter tierods also. I did reuse my new poly bushings in it though. I paid $265 and didn't have to send back my old rack. Got to keep it, may try to rebuild it myself one day. I installed it myself. Not to bad of a job, at least I have a covered carport with concrete. I hate working in the dirt, done that to many years.
  8. Apr 30, 2013 at 3:18 PM
    TIPICOTACO
    Tyler
    nw nj
    ^ no core charge? where'd you score that kinda deal?
  9. Apr 30, 2013 at 5:32 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    there are write ups on rebuilding the rack... changing seals etc...
    but sourcing those parts will be a pita...
    and some special tools may be needed.
    I recommend replacing the rack...
    and with the newer rebuild design that has the updated
    rack guide assembly incorporated.
    Pay the extra for the lifetime limited warranty...
    and you'll never need purchase another. ;)
    ^ but that don't mean you won't need another.
    Lol
  10. Apr 30, 2013 at 5:59 PM
    sethcooke
    sethcooke Member
    i had the same problem. i was going through a bottle of power steering fluid a day but i dropped some lucas stop leak in it and it hasnt leaked in at least 4 months, so if i was you id spend the 20 bucks it cost and get yourself some. Dont get any other brand but lucas, all the other stuff sucks
  11. Apr 30, 2013 at 6:07 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Wrote this response earlier this week on a different post...
    Rackdoctor
    Life time warranty....
    http://www.rackdoctor.net/
    And they sell those poly bushings.
    Way better than used, Toyota or an auto store....they only offer LIMITED lifetime.
    As for the leak, make sure you are not using power steering fluid.
    Use ATF fluid with DexIII
    Why, because the seals used are the same as the transmission.
    Is you use PS it will degrade the seal and allow the fluid to leak.
