Leaky sunroof
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjillson, Sep 22, 2017.
  1. Sep 22, 2017 at 6:31 AM
    mjillson
    mjillson [OP] Well-Known Member
    Hello fellow Tacoma owners,
    This has probably been addressed in the past, but I can't seem to good answer (even from my local Toyota dealership). When it rains, and my sunroof is closed, I can see water dripping down into the plastic tray below. Toyota said that is by design, but I've never owned a vehicle where I can see water dripping in. I know a lot of cars have a runoff through the door but this doesn't seem normal to me. It currently doesn't end up in the cabin but it just seems weird. I could see if it was a drop or 2 but a decent amount of water pools up in the plastic catch plate. Any input would be appreciated.
    Thanks!
  2. Sep 22, 2017 at 6:36 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    not normal, i go through a high pressure touchless car wash on occasion and even then i have only seen water once and it was not enough to form a droplet
  3. Sep 22, 2017 at 6:49 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Maybe the drain holes are plugged a bit?
  4. Sep 22, 2017 at 6:52 AM
    mjillson
    The dealership checked that and said they were fine. They also "water tested" it for a few hours and said it did not leak. Mind you, every time it rains (even a misty rain) it starts dripping. I took a video for them to see and they still claim that it is normal.
  5. Sep 22, 2017 at 6:56 AM
    Herniator
    Edmonton
    mine doesn't leak at all. Not in heavy rains or in any carwash.
    Maybe it needs to be recalibrated. From closed position, press the vent open button. when it stops, press and hold the button again for about 10 seconds. The sunroof should go through a cycle where it opens and closes. Try that. Maybe it needs to close just a bit more.
    shakerhood likes this.
  6. Sep 22, 2017 at 7:00 AM
    mjillson
    Thank you, I will try that. When I bought the vehicle 4 months ago the sunroof was never programmed so when I tried to open it it would continue to try to open and make a grinding noise. Toyota said "I should of programmed it when I got home" but maybe that did some damage to the seal. I will def try to re-calibrate when I get home to see if that helps it out. We have rain in the forecast so I should get an answer pretty quick.
    Thanks!
  7. Sep 22, 2017 at 7:03 AM
    Herniator
    Edmonton
    The dealer is supposed to calibrate the sunroof as part of the sale. You pay a prep fee and thats part of the fee.
    My sunroof wouldn't close automatically from a vent position. So I recalibrated it last week. Now it works like a charm. Hopefully this helps you too.
  8. Sep 22, 2017 at 7:03 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    there's another thread on this, he saw the same thing, dripping into
    the lip, dealership told him the same thing. It's rained like crazy here
    the last few months and I've never ( I check every time it rains ) seen a single drip.
    Herniator likes this.
  9. Sep 22, 2017 at 7:32 AM
    mjillson
    Thanks. I feel like this is something that is a problem that they dont want to address. BTW, your truck looks badass.
  10. Sep 22, 2017 at 8:26 AM
    McEZ
    McEZ Member
    Eric
    College Station, TX
    2017 TRD Sport DCSB
    Softopper, Kicker Speakers, Husky Liners, Car Seat, ShiftSense Pro V2, Tyger Auto Steps, Bed Mat, Bed Rail Header, Door Sill Protectors, Sprint Booster, OCD Console Divider, Clazzios
    Mine drips as you describe. If you look back between the headliner and back seal on the sunroof you can see it dripping into a plastic tray that drains it down the B pillar. I saw in another thread here that said this is by design. I was more than a little concerned when I first saw it. Never seen a drop of water in the cab.
    Hopefully this video works... https://photos.app.goo.gl/BS9VB43QBiMopsTp1
  11. Sep 22, 2017 at 8:30 AM
    mjillson
    OK, so that is EXACTLY what mine is doing. I feel like this isn't normal and it's something Toyota is brushing off.
  12. Sep 22, 2017 at 8:52 AM
    toyguyic
    toyguyic Well-Known Member
    kdog
    Iowa City, IA
    2017 Tacoma Limited White
    TRD Pro Grill, Lo Pro QT, Morimoto HID
    That's perfectly normal. The outer seal is designed to hold water back, not completely seal. The inner channel has holes that run through the pillars and drain the water. As an example, close the sunroof completely and from the outside push lightly on the front or back of the sunroof and you'll notice it moves around, floats so to speak. As long as you don't get wet it's doing its job.
    Plain Jane Taco and McEZ like this.
  13. Sep 22, 2017 at 8:52 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No drips on mine, it was also already programmed at the dealer before I brought it home.
  14. Sep 22, 2017 at 9:44 AM
    BlkTaco47
    BlkTaco47 Unhinged
    There's just no way it can be "by design" if we are not all seeing it.
  15. Sep 22, 2017 at 9:52 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    No drips here---also haven't taken it through an automatic wash so unsure if it would happen with pressure but no drips in rain storms
  16. Sep 22, 2017 at 10:04 AM
    Tacoma1818
    Tacoma1818 Well-Known Member
    I'd clean the seals and then put some 303 aerospace on them. Clean the seal and the metal it presses against.
  17. Sep 22, 2017 at 10:15 AM
    Tacowin1013
  18. Sep 22, 2017 at 10:26 AM
    TravoHTX
    TravoHTX 2017 TRD OR
    Travis
    Westminster, Colorado
    I get the drips. Odd to see for sure but waters never gotten inside anywhere. I think I'll try the re-calibration method above just to see if it works
  19. Sep 22, 2017 at 10:28 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It really is normal. That's what that tray is for. The tubes takes the water away. If the roof was completely sealed against water you wouldn't be able to open it
    toyguyic likes this.
  20. Sep 22, 2017 at 10:31 AM
    BlkTaco47
    BlkTaco47 Unhinged
    which post?
