Lean bank 1
Discussion in 'Performance and Tuning' started by Hp4Play, Apr 13, 2015.
  1. Apr 13, 2015 at 3:09 PM
    Hp4Play
    Hp4Play [OP] Well-Known Member
    Andy
    Tempe
    double stuffed taco
    I have the super charger but when I intall a throttle body spacer I get a lean bank 1 engine code. Not sure why this is happening. Before the super charger no code. With the supercharger there is a code. I pulled all the spark plugs and none of them are running lean. It does however have a little more throttle response it seems with it on. Does anyone have an idea why this may be happening?
  2. Apr 14, 2015 at 8:28 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Do you still have the OEM headers and Y-pipe
  3. Apr 14, 2015 at 8:55 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Only thing I can think of is an air leak around the spacer. That would be the only reason.
  4. Apr 14, 2015 at 9:27 AM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    That's what I was thinking but I sprayed some cleaner around it and no change in engine speed.
    Yeas I still have the stock headers and y pipe. That's my next upgrade. Still trying to decide which brand to go with.
  5. Apr 14, 2015 at 9:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You have either a vacuum leak some where, or an exhaust leak. My money is on the vacuum leak. If you take pictures of your engine bay, from multiple angles, we all could help you better.
  6. Apr 15, 2015 at 11:52 AM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    OK so i sprayed some carb cleaner around and the only sp0t that it affected was when I sprayed around the bypass valve diaphragm. it died... i don't know if that's normal or not so I just went ahead and purchased a new one as it wasn't replaced with the rebuild and I have no idea the age or miles that are on it. I/ll take some pictures today and post them up see if that helps you guys at all.
  7. Apr 15, 2015 at 11:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There you go.
    What about the nipple next to it where the vacuum/boost reference is used? Don't know if you have a gauge attached or of the vacuum cap is leaking?
  8. Apr 15, 2015 at 1:00 PM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    I have the fuel pressure regulated thing hooked up to it as per the vaccum diagram in the distructions.
  9. Apr 15, 2015 at 1:37 PM
    elnip
    LC,NM
    x2
  10. Apr 15, 2015 at 2:18 PM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    Why would it only throw a code with the spacer attached though?
  11. Apr 16, 2015 at 5:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can't say specifically without physically looking at your engine. Or at least pictures or video.
  12. Apr 16, 2015 at 11:32 AM
    Vassily28
    The ecoblock put your LTFT closer to his limit (before an error code), so maybe any air flow problem related can push you over the limit.
  13. Apr 16, 2015 at 2:44 PM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    ill post up some pictures today. i spaced it the other day. had a lot going on.
  14. Apr 19, 2015 at 7:01 AM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    The bypass valve fixed the check engine light thanks guys.
  15. Apr 19, 2015 at 10:23 AM
    Vassily28
    What was the problem exactly?
  16. Apr 24, 2015 at 9:02 AM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    The seal on the bypass valve was leaking air. Still haven't seen the check engine light come on since replacement. The problem stemmed from the throttle body spacer. With it on it would throw a code. With it off no code would show up.
  17. Apr 24, 2015 at 9:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is very strange how that spacer showed there was a problem. Kind of cool, since now your engine runs better and makes more power.
  18. Jul 19, 2015 at 6:09 PM
    Hp4Play
    Andy
    Tempe
    double stuffed taco
    this is the bypass valve ... i guess you cant attach pictures to the conversations.
