Lean condition??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burnttaco, Apr 6, 2015.
  1. Apr 6, 2015 at 8:45 AM
    Burnttaco
    Burnttaco [OP] Member
    Pat
    AZ
    2014 DCTRD
    So, I have a 2014 DC 4X4 OR with 16K miles. When I punch it, I hear a ticking noise form the engine. Asked the service dept. about it and got a bunch of BS with no action. Sounds like a lean condition to me. Still on warranty. Should I raise hell with them? Would a CAI/ CAT back system help? My last Harley did this from the factory. Opening the airbox and adding new open exhaust slip-ons cured it.
    I'm open to any input.
    THX,
    BURNTTACO
  2. Apr 6, 2015 at 9:14 AM
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    running 87? Try some mid grade.
    There is also a TSB to address this issue.
  3. Apr 6, 2015 at 10:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    dont worry about it, classic taco tick.
    That stated there is a reflash for our trucks for pinging. Might have the dealer reflash.
  4. Apr 6, 2015 at 6:54 PM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    Yeah, mid grade. I'll have them do a reflash and then try mid grade.
    THX
  5. Apr 9, 2015 at 12:18 PM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    What is a "TSB"?
  6. Apr 9, 2015 at 5:49 PM
    Why J
    Technical Service Bulletin
  7. May 9, 2015 at 8:22 PM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    Local service dept. did a reflash today as per TSB. GREAT results. Thanks guys!!
  8. May 9, 2015 at 8:25 PM
    Butterless Toast
    Butterless Toast Well-Known Member
    NKY
    2015 Tacoma TRD Sport
    Should be the opposite. More airflow = more fuel. Most motorcycle engines require a jet kit or at least a carb adjustment when opening up the airflow. Glad you got the Taco taken care of!
  9. Jun 3, 2015 at 2:27 PM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    The saga continues....
    Hot weather in AZ now and pinging again. Dealer said it can't be reflashed with a different program and that I should try mid grade again. Also said that "we are still doing winter gas which has more alcohol and should change when summer gas arrives...WTF.
    Might a cooling shroud from Bulletproof cool it down more and eliminate the pinging? It is predetonation (pinging) and not ticking.
    Thoughts?
  10. Jun 11, 2015 at 10:08 AM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    Any thoughts on the Bulletproof cooling shroud?
    THX
  11. Jun 11, 2015 at 10:55 AM
    nd4spdbh
    SoCal
    link?
  12. Jun 11, 2015 at 1:01 PM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
  13. Jun 11, 2015 at 1:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Excess air would find path of least resistance and blow around side of radiator anyhow
  14. Jun 11, 2015 at 1:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Damnit!!! I was asking people to make that years ago!!!!!!!! Now I finally see it....It will help to force the air through. If you ever get the chance to look at a 4Runner with the hood open, you will immediately notice that they have extensive shrouding compared to the Tacoma. Their coolant temps naturally run lower under heavy useage than the Tacoma because of this. They do not need this cooling panel. For us, it will help some. Not as much as having it on the sides as well, but it will still be an improvement. :thumbsup:
    Justus likes this.
  15. Jun 11, 2015 at 1:33 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Cusco makes one for FJ's as well. FJ's get all the goodies.
  16. Jun 11, 2015 at 2:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    FJ's and 4Runners alike. :frusty: A lot of parts I look for have to come from either of those......
    OP, you said you have been using mid-grade gas. You live in AZ correct? Have you tried getting on "E" then filling up with say a quarter to half tank of premium?
    What are your coolant temps?
    Does it ping at night when it is cooler outside? What is the temp of "cooler"?
    Does it ping on mid-grade? (Since we already know it pings on 87.)
    You have the air injection system, so that will make things a tad warmer, unless for some reason it isn't working right and possibly stuck in a manner which is basically open. Then it would get a lot hotter.
  17. Jun 11, 2015 at 3:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm starting to think that it is the gas itself. Which brand do you use? If it isn't top tier, definitely switch to it.
    Then go by the lowest grade which doesn't ping.
  18. Jun 25, 2015 at 8:51 AM
    Burnttaco
    Pat
    AZ
    2014 DCTRD
    Yeah. Need to continue with higher grade/ brand name fuel experimentation. Will report results.
    Pings when hot, pulling up hill and accelerating....not limited to punching it. Temp gauge not reading excessively hot. Reflash did nothing to improve pinging. Yeah, I have been running cheap gas.
    Thanks for input.
  19. Jun 25, 2015 at 9:29 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Pretty amazing the stuff a dealer will say to wiggle out of a situation.
    [​IMG][​IMG]
  20. Jun 25, 2015 at 9:40 AM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Im in AZ, 2013 tacoma, and I use mostly frys gas, run 89 when driving on highway,91 when towing and 87 in town. I have no pinging and havent needed to do the reflash tsb. It may be the gas you use
