Leaning Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by HARDSHELLTACO, Apr 24, 2009.
  1. Apr 24, 2009 at 7:30 AM
    HARDSHELLTACO
    HARDSHELLTACO [OP] HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I have seached several forums for solutions to the taco lean and it seems to me that most involve a spacer on the front coil, or adjustable coilovers. My issue is on the driver side rear. I pulled my truck in my garage and measured from the floor to the bottom of all four fenders all were approx 39" except driver rear was 38". Any advice would be appreciated.
  2. Apr 24, 2009 at 9:01 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Your rear leaf spring may be de-arching causing you to have one side lower than the other.
  3. Apr 24, 2009 at 9:03 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Are you sure the apparent left-rear discrepancy isn't just the bed itself (e.g., warped; mounting is a bit 'off'), rather than the actual way the suspension 'sits'?
  4. Apr 24, 2009 at 9:25 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    How would you check for such a thing!
  5. Apr 24, 2009 at 2:54 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    measure the frame *shrugs*
    Its called the Tacoma Lean we all have form of it.
  6. Apr 29, 2009 at 9:11 AM
    ViperR
    ViperR Active Member
    NC
    bare-bones
    Since the fuel tank is on the drivers side and there is usually just the driver, for the most part, that spring is relaxing compared to the opposite spring because of the weight over the years. I have this lean on my 95.5 and 97. I fixed the problem on the 97 without any $$ by swapping the springs. Yet to do this on the 95.5. It has labor to it, but is the cheapest fix.
  7. Apr 29, 2009 at 9:16 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    After further examination I have decided it's not as bad as I thought so i'm going to leave it be.
  8. Apr 29, 2009 at 6:06 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    my driver rear is about 1/4" lower, not that bad. But I was wondering, what size tires do you have?
  9. Apr 30, 2009 at 8:57 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    285/70/17
