Learn From My Mistake - Replace Plastic Oil Filter Housing With Metal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by loveinyourmouth, Apr 24, 2018.
  1. Apr 29, 2018 at 12:18 PM
    #41
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yes the filter comes with both O-rings, you just need some 0w-20 and a drain plug gasket and you are good to go. Mobil 1 has a $12 rebate if you snag it before the end of May.
    #41
  2. Apr 29, 2018 at 12:24 PM
    #42
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Yes I am buying 3 jugs of mobil1 to get 2 rebates. Only $23 a jug at Walmart so 1 jug will be free. Just ordered 5 filter kits for $25. Do these drain plugs require new gaskets each change. I only replaced those gaskets as needed for all my other vehicles. Actually planning on putting a quick change valve in it anyway so a non-issue. With the TRD skid I want to minimize the mess. Only thing left is buying a quality wrench.
  3. Apr 29, 2018 at 12:45 PM
    #43
    shakerhood
    Southern Ohio
    I always replace drain plug gaskets, but I am sure you could get by a couple changes.
  4. Apr 29, 2018 at 1:34 PM
    #44
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    I got tired of changing o-rings and worrying about the plastic housing. Bought the Baxter spin-on adapter and life is much easier.
    stun gun and shackley like this.
  5. Apr 29, 2018 at 2:09 PM
    #45
    mrproduxn
    steve
    Retired DoD SE VA
    I looked into those but I can do nearly 6 years of oil changes, at 7500 miles a year, cheaper than that adapter.
    hrivera007, Skydvrr, newb13 and 2 others like this.
  6. Apr 29, 2018 at 2:58 PM
    #46
    newb13
    newb13 Well-Known Member
    greg
    winter park florida
    2016 sr5 DCSB v6 blue
    de-badge and tint,tri-fold tonneau,rims and tires
    my exact question-almost. filter did come with orings. im thinking 5-20. im in florida. prob gonna do mine tomorrow or tues.
    #46
  7. Apr 30, 2018 at 7:04 AM
    #47
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Reviews were showing cheap knock-off warnings.
    NorrinRadd, TRDPro916 and Skydvrr like this.
  8. Apr 30, 2018 at 7:34 AM
    #48
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    The reviews may be correct almost every Toyota part label has a genuine hologram looking sticker on it when putting into light and moving it around you’ll see Lexus
    Toyota on it
    NorrinRadd likes this.
  9. May 4, 2018 at 1:46 PM
    #49
    mrproduxn
    steve
    Retired DoD SE VA
    OK so I got the aluminum filter housing, 3 oil changes of mobil1, 5 Toyota brand filter kits and a quality filter housing wrench. My new aluminum housing arrived with the tube but has no drain plug. Do I need to buy a metal plug or is everyone using the one from the plastic housing. Is the oem plastic or metal. Did not look before I mounted my skid. No rush because it will be December before I need an oil change. Just figured I would stock up now while mobil1 rebate is still on. Thanks.
  10. May 4, 2018 at 4:37 PM
    #50
    Taco_AZ
    Taco_AZ Active Member
    Litchfield Park
    2017 Super White Tacoma TRD OR 4x4
    You just use the one from the plastic housing it will Work and it’s metal.
  11. May 4, 2018 at 5:01 PM
    #51
    mrproduxn
    steve
    Retired DoD SE VA
    Thanks. Just saved me $7, or as they call it in California, a gallon of gas.
    Taco_AZ[QUOTED] likes this.
  12. Aug 2, 2018 at 5:31 PM
    #52
    Joisey
    Joisey Well-Known Member
    I wonder if the people at the dealer are lubing the O ring before they put it on, and wiping the inside of the housing where the O ring seats with clean oil before snugging things up. A dry O ring will be a bitch to remove.
    Years back I worked at a GM dealership. Two guys did all the oil changes, both in their sixties. One guy was retiring by the end of the month. He took the square O ring seal off of each filter and wiped it on both sides with chassis grease, then did the oil change as normal. Months later when those cars came back for an oil change (this was in the time of 3K oil changes) the remaining oil change guy had to get the filters off with a screwdriver or a strap wrench, depending on what would fit. Grease made the rubber gasket swell and stick.
  13. Aug 3, 2018 at 6:52 AM
    #53
    loveinyourmouth
    loveinyourmouth [OP] Well-Known Member
    2016 Tacoma DCSB SR5 4x4 - Red
    Bone stock
    Update: just did my first oil change with the new filter. It came off without a fight. Everything is great!
    Tip for anyone else who saw someone recommend the oil filter drain hose - do not buy it. It’s a complete waste of money for this truck. When hooking up the hose, there’s barely enough oil in the filter to make it through the hose.
  14. Sep 16, 2018 at 5:36 PM
    #54
    lovepd
    lovepd New Member
    2016 Toyota Tacoma TRD Sport
    I share similar if not exact frustrations regarding oil changes in my Tacoma that it seems a lot of the community members share. Namely, I've been unable to loosen my factory oil filter housing thus forcing me to get my oil filter changed elsewhere which is more expensive and in my opinion not as satisfying.
    My question to the community is what are my options for getting the plastic oil filter housing off? I've seen that some members have resorted to using a breaker bar and/or maybe some other power tools (neither of which I own). Should I purchase some auxiliary tool or should I just purchase a metal housing unit and politely ask the mechanics who end up changing my oil to replace the plastic housing with the metal housing when completed?
    Thank you in advance for any help, guidance, and/or suggestions y'all provide!
    pdeinc likes this.
  15. Sep 16, 2018 at 5:43 PM
    #55
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    are you guys uncllipping the safety clip at the top of the housing? And lining up the grooves in the wrench with the those on the housing?
    NorrinRadd and Blacklodge like this.
  16. Sep 16, 2018 at 5:54 PM
    #56
    loveinyourmouth
    Bone stock
    Yes.
  17. Sep 16, 2018 at 5:57 PM
    #57
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    I use prime series 5w 30 from Sam's club.
  18. Sep 16, 2018 at 5:58 PM
    #58
    Jh8473
    Bowling Green
    2025 Tundra SR5
    None
    My safety clip doesn't even touch the housing.
    pdeinc likes this.
  19. Sep 16, 2018 at 6:19 PM
    #59
    jriddick
    jriddick Member
    Jeremy
    SE Virginia
    2006 OFFROAD
    Smittybuilt Steps, Alpine Stereo All Around, Remote Start, Bilstein 5100s, EBC Rotors and Pads, K&N Drop-In, FJ wheels, WeatherTechs, debadged, Dark headlights and fogs, 22" LED lightbar
    My experience (unfortunately) trumps all:
    I “inherited” a 2012 Corolla when I got married. All previous oil changes were under warranty. My first oil change was unsuccessful because I COULD NOT get the plastic housing out. I had a filter tool but it didn’t work. It was a cold day so I decided to wait until it was a little warmer and order the Toyota filter tool. So...new tool, warmer day, breaker bar...nothing.
    Long story short, the plastic housing was stuck. Real stuck. I ordered a brand new housing AND the ported metal bracket (that bolts to the block and accepts the plastic housing). I just replaced the whole thing. With the old off the vehicle, it took a 2 foot pipe wrench, a heavy duty bench vise and significant abdominal straining to break it loose.
    Unfortunately, to make matters worse, I foolishly installed the new o-ring in the wrong spot on the new plastic housing since I didn’t have the old for reference. So, about 2 seconds after the engine started for a leak check...oil sprayed everywhere.
    Needless to say, I was frustrated. Oil changes should be easy! And I also keep a picture with the correct o-ring installation location on my phone.
    Photos:
    - the metal bracket
    - the reference photo (with a dirty filter. On my failed attempt I put the o-ring lower vs in the slot where it resides in the photo)
    bush rat, NorrinRadd and SilverII like this.
  20. Sep 16, 2018 at 7:38 PM
    #60
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    used same as 2012 rav 4 , v6 3.5 metal housing.
    shackley likes this.
