Learn me on building a Glock
Discussion in 'Guns & Hunting' started by skierd, Dec 30, 2019.
  1. Jun 29, 2020 at 11:38 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    In addition to this and regardless of caliber...one has to be very proficient (under high stress) to effectively place a round in the proper location.
  2. Jun 29, 2020 at 12:07 PM
    skierd
    skierd [OP] Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    https://www.alaskapublic.org/2019/06/07/bear-awareness-and-safety/
    Take a listen if you’re interested in a serious discussion the topic. It’s not the hide, it’s penetrating the skull. 9 and 40 can do it with the proper bullet, something heavy for caliber and hard cast flat pointed solid lead.
    I can, and enjoy, practice with my handguns. At $40 a can I’m not going to be able to practice with bear spray nearly as often. You still have to hit a charging bear in the face with it, so you still need to practice (and hope you aren’t upwind).
  3. Jun 29, 2020 at 12:54 PM
    Planespotting
    Planespotting Well-Known Member
    Miles
    Michigan
    2019 SR5 V6 DCSB, '74 FJ40, 05 Ducati Multistrada S
    Decals!
    Reading the studies in your link a few things jump to mind:
    1) Although the shooter may be able
    to kill an aggressive bear, injuries to the shooter and others
    also sometimes occur. The need for split-second deployment
    and deadly accuracy make using firearms difficult, even for
    experts. Consequently, we advise people to carefully consider
    their ability to be accurate under duress before carrying a
    firearm for protection from bears. No one should enter bear
    country without a deterrent and these results show that
    firearms are not a clear choice.
    Efficacy of Firearms for Bear Deterrence
    in Alaska
    2) Firearms failed to protect people for a variety of reasons
    including lack of time to respond to the bear (27%), did not
    use the firearm (21%), mechanical issues (i.e., jamming;
    14%), the proximity to bear was too close for deployment
    (9%), the shooter missed the bear (9%), the gun was emptied
    and could not be reloaded (8%), the safety mechanism was
    engaged and the person was unable to unlock it in time to use
    the gun (8%), people tripped and fell while trying to shoot
    the bear (3%), and the firearm’s discharge reportedly triggered the bear to charge that ended further use of the gun
    (1%).
    in Alaska
    3) Although firearms were successful (84% handgun; 76%
    long gun) in deterring aggressive bears in the records we
    studied, we do not claim that these rates represent the
    outcome for all bear–firearm incidents throughout Alaska.
    in Alaska
    4)
    Success rates by firearm type were similar with 84% of
    handgun users (31 of 37) and 76% of long gun users (134
    of 176) successfully defending themselves from aggressive
    bears
    in Alaska
    Although bear spray was 92% effective by our definition of success, it is
    important to note that 98% of persons carrying it were
    uninjured after a close encounter with bears.
    Efficacy of Bear Deterrent Spray in Alaska
    This is why I decided to go spray instead of firearm. Also, in many National Parks it is illegal to carry a firearm. Sprays are allowed. Of course the #1 deterrent is to avoid putting yourself in situations in the first place. While it can't prevent surprise encounters good trail safety and camp safety should be the very first step.
    skierd[QUOTED][OP] likes this.
  4. Jun 29, 2020 at 11:30 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    maybe the ' Glock Store ' can help U with a Single Stack 10 MM
    no less maybe point U in a good direction
    the ' 454 CASULL ' is carried by many around bears
    UNquestionable knock power ...................... Not many bullets
    reliable as hell
    big recoil
    thing is the numbers U crunch dont advise U about the nature o bears
    tho encounters are seldom
    they are NOT UNawares by the bear
    the bear KNOWS U r there !!!!!
    when in sight proximity................. the bear oft times will circle
    more the reason i would NOT overly trust spray
    a charge is both Defensive/Offensive
    apex predators dont like being crowded.................. U are in Their Zip Code !!
    good luck
  5. Dec 20, 2020 at 12:42 PM
    mattys010
    mattys010 Well-Known Member
    2010 DCLB TRD Sport
    I like my Glock 20. Modding it sounds cool but I will leave it alone, it works great.
