Learned something about our door locks today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fixnfly, Jan 25, 2013.
  1. Jan 28, 2013 at 4:11 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ask the dealer if you can have this programmed in...some cars this is just a setting...the ecu is capable of doing it anyhow
  2. Jan 29, 2013 at 6:11 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    And, with the key, you can also lock both doors manually from either side, and from the driver's door unlock just the driver's side, or both doors, and when you go to unlock the truck manually from the passenger door, both doors will unlock at the same time...:cool:
  3. Jan 29, 2013 at 6:55 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Yeah, I was wondering about that. Don't know if anyone has ever tried or not.
  4. Apr 10, 2013 at 10:45 PM
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Mine does not do this. I have tried all day to make the alarm sound, but it will not. I have the keyless entry and remote, but there is no alarm. Is there an upgrade factory alarm system module or something? My Sienna SE doesn't work like this either. Any help would be appreciated. I would like them both to sound the horn when somebody forces the door open.
  5. Apr 10, 2013 at 10:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Security feature.
    Remember, there are a limited number of codes.
    In an area like Los Angeles, there is a GOOD possibility that another vehicle with your code will end up in the same parking lot.
    This way, if someone else unknowingly unlocks your vehicle, it's not left unlocked for the next hour, day (or maybe at LAX), week.
    Maybe not such an issue today with rotating codes and the remote being programmed to match the ECU, but that is more recent.
  6. Apr 10, 2013 at 11:00 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    x2. i hit the unlock on drivers door all the time when i need to get to in the back door.(some times i for get to hit the unlock 2 times)
  7. Apr 10, 2013 at 11:05 PM
    bullaculla
    Honolulu HI
    :ahem: :eek:
    Is my truck the only one that doesn't do this?
  8. Apr 10, 2013 at 11:09 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    no. i put my windows down, and locked it with the fop, and waited a few min reached in and opened the door and it did nothing. tried locking it with the lock button on the door same thing nothing at all.
  9. Apr 10, 2013 at 11:09 PM
    zach nunes
    zach nunes it looks stock, but with a little zest
    zach
    chico/carmel
    09 4x4 SR5
    a little zest here and there
    I used to remote unlock in my house and run like hell out to the truck befoLOCK....yeah that's how I figured it out.
  10. Apr 10, 2013 at 11:20 PM
    bullaculla
    Honolulu HI
    Thanks. Does anyone know if there is an OEM system available? I hate to get an aftermarket alarm with an extra key fob.
  11. Apr 10, 2013 at 11:30 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    no problem! and i want to get a viper and dill ditch the oem fob and just use the one viper gives you. because at that point the oem wont do anything anyways. either way you are probably going to end up with a new key fob, wether it’s oem or aftermarket.
  12. Apr 11, 2013 at 1:26 AM
    bullaculla
    Honolulu HI
    Gotcha, Thanks!
  13. Apr 11, 2013 at 1:29 AM
    bise101087
    bise101087 Member
    Justin
    Wichita
    2010 4x4 trd
    Upgraded Head unit
    havent tried to unlock my seat without any weight on the seats, but im going to try it now just to see if mine will do it. i imagine it would need weight off of both passenger seats and driver seats since they both have sensors??
  14. Apr 11, 2013 at 2:34 AM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, pelfrey ifs skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    My truck alarm used to go off like that a couple years ago, not anymore though.:confused:
  15. Apr 11, 2013 at 1:50 PM
    #35
    fireroad
    fireroad Well-Known Member
    My truck is a 2012 and did not do this at first. I found out the hard way as it got broken into the third week I had it while of vacation in Phoenix. As soon as I got home I had the dealer install a factory alarm for around $380. In addition to the "lock after 45 sec if you don't open the door" it now does the loud alarm if you reach in and open the door handle or hit the unlock button. Also includes glass sensors if they try a smash and grab. I believe something changed after 2011 because my buddies truck sets of an alarm when you try to open from the inside and he did not get the factory alarm. My guess is that a "factory alarm" was an option at one point or in certain areas and some folks may have it without knowing.
    I am sure their are better and/or cheaper alarms out their but I like the fact that this works with the original key fob. I was pissed I had to shell out money in the first place as my 01 GMC Sierra had the equivalent of this alarm standard.
    The TVIP RS3200Plus (Toyota Vehicle Intrusion Protection) is a complete vehicle security system with alarm and glass breakage sensor for vehicles that already have keyless entry with remote lock/unlock. The TVIP RS3200 offers three different alarm functions; break -in alarm, warn-away alarm and panic alarm. When armed, the vehicle’s security system is activated immediately if forced entry of a side door (or the trunk) is attempted or if the glass is tapped or broken. The system’s wide range of security and convenience features include: remote arming and disarming, automatic rearming and relocking, passive arming, door ajar warning, interior light activation, rolling code technology and disabling of the starter.
    Backed by Toyota's 3-year/36,000-mile New Vehicle Limited Warranty, valid at any Toyota dealership nationwide.
    Designed to integrate with the vehicle’s existing factory security/keyless entry system—no need for an additional remote
    Alarm functions
    Panic alarm remotely triggers vehicles alarm when activated from key fob
    Warn-away alarm triggers an alarm triggers if an object striking on a window is detected
    Break-in alarm is activated or if forced entry of a side door (or the trunk) is attempted or if glass is broken
    Other features include
    Door ajar warning helps remind driver to lock vehicle
    Remote arming and disarming with 80 foot range
    Passive arming— system automatically rearms and locks the vehicle if owner forgets
    Automatic rearming and relocking
    Interior light activates when vehicle is unlocked with key fob
    Rolling code technology changes the remote code, helping prevent code theft
    Starter disabled when system is activated
    Includes glass breakage sensor (GBS)
    Highly sensitive microphone detects the specific sound frequency of striking on glass or glass breakage
    Sounds alarm and disarms starter if a window is broke
    Sounds a warn-away alarm if object striking on a window is detected
  16. Apr 11, 2013 at 2:58 PM
    #36
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    On my 2012 it will not lock with the fob when the engine is running. I tried doing it this winter to warm up the truck and lock my doors.
  17. Apr 11, 2013 at 6:28 PM
    #37
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Just wanted to let you guys know that if you want a cheap key to open your doors go to Lowes. For under 3 bucks you can get a key(without a chip in it) and it will lock and unlock your doors but it will not start your car. I like to let my truck run for about 10-15 minutes in the winter to warm up. I didn't like leaving it running unlocked and I didn't want to carry both sets of keys with me. I stopped at Lowes and had an unchipped key made and use that key to lock and unlock the door while my truck is warming up. If some idiot wants to smash a window to steal it they are going to freeze to death driving around with the busted window.
  18. Apr 11, 2013 at 6:37 PM
    #38
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Pretty sure you can lock your running truck from the outside using a key in the lock.
  19. Apr 11, 2013 at 6:56 PM
    #39
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Yeah, I got an un-chipped key to keep in my wallet. Just in case kinda thing, but I use it a lot to lock and un lock my doors if I'm just running to my truck to grab something and don't have the fob. I also use it to turn on to the accessories in ignition to turn on my Sirius radio, than I can tune a radio outside the truck to listen to that. Good for tailgating and what not, and no one can jump in and start it. A little peice of mind.
  20. Apr 11, 2013 at 8:33 PM
    #40
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    I had a '94 Camaro that did the same thing. I locked the keys in there, so I used a thick coat hanger to jam the hell out of the button and ... nothing. It only worked to manually pull the door handle. Buttons worked fine with the door open, but when they were closed there was no triggering the switch.
