Least expensive way to raise truck 1"-2"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbs1, Nov 7, 2013.
  1. Nov 10, 2013 at 4:24 PM
    #41
    steveo27
    steveo27 Ask me about my weiner
    Steveo
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    How does it ride with the taller springs vs using the OEM springs? My 5100s are set a 1.75 right now. I wanna bring the fronts up a bit more, so its either adjust them up to 2.5" or installer taller springs.
  2. Nov 10, 2013 at 7:42 PM
    #42
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Hockey Pucks ;)
  3. Nov 10, 2013 at 8:53 PM
    #43
    Kasbien
    Kasbien Well-Known Member
    Kellen
    Vancouver, BC
    07 SR5 4x4 6MT
    Icon 2.5 C/O's, Icon 2.0 Shocks, LR UCA's, OME Dakars, Boxed CMC, Homebrew Bolt-on Sliders, Braided Brakelines, Spidertrax Spacers, Poly Bushings all over, Custom TRD SS, Marlin Shifter Seat, Added Fog Lights + Anytime Mod, Weather Techs, LED's, Shortened Antenna, 10" Pioneer Sub, BOSS R1600M Amp, Painted some shit.
    After seeing this, I think this will be the future route for me to take since I'm not into off-roading yet and don't need the 2"-3" lift I have right now.
    I have a spacer lift in the truck left behind from previous owner and I HATE it. Because of it, I avoid speed bumps or any other changes in flat pavement at all costs.
  4. Nov 10, 2013 at 9:15 PM
    #44
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    whenever I need to lift my truck, I borrow a neighbors jack :laughing:
    and that sir, is free
  5. Nov 10, 2013 at 9:42 PM
    #45
    stumblestacks
    stumblestacks Well-Known Member
    North lake Tahoe
    Beat up 98taco 3.4L limited xtracab TRD
    Finally blew the motor at 230,000, sprung for a Jasper with 100,000/3 year warranty. The birdpig has a new set of wings! OME heavy load lift kit, Dakar leafs w/AAL, frame mounted energy suspension 4.5" bumpstops, 882 coils, nitrocharger sport shocks, trail gear sliders, addicted offroad front bumper, KC 130w daylighters, Warn M8000, 31" BFG KM2's, custom dents and Nevada pinstripes.
    I went with OME heavy load Dakars with AAL and 883 coils with OME nitrochargers all around. It's pretty stiff unloaded, but rides great with some weight in back. The front was stiff before I put on my bumper and winch, now it rides perfectly. I destroyed two sets of leafs before I added 4.5 inch bumpstops mounted on the frame. Now it never goes into negative arch even at "full stuff." I went with the soft energy suspension bumpstops. They compress a lot so you barely feel it when the leafs hit them. Blocks and spacers are cheap and fine for looks, but as others have said, no good for off road. spacers change your spring rate, limit up travel, and overextend down travel. Blocks focus the weight on the contact points on your leafs and the "flat spot" changes the way they flex. I back OME after they replaced 2 sets of negative arched leafs free on warranty, even though it was my fault for not extending my bumpstops equal to the amount of lift. 3rd time's the charm. This setup handles great on freeways, windy bumpy roads, washboard, sand, and rocks. Some say you should shim your axle and move your drive shaft bearing to compensate for the increase in drive shaft angle/extension. I didn't, 2 years with no problems. Time will tell.
  6. Nov 13, 2013 at 5:46 PM
    #46
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    ^^ Bad ass truck!!^^
  7. Nov 13, 2013 at 6:26 PM
    #47
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Lots of these :D
