least fussy way to get up to 1" additional ground clearance on SR5?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by M16, Nov 4, 2015.
  1. Nov 4, 2015 at 6:20 PM
    M16
    M16 [OP] Well-Known Member
    obviously there's a ton of information (and folklore and pretty transparent disinformation) in the threads on lifting a Taco. God knows I've sifted through a lot, and have learned a bit. But I still don't have a handle on a simple way to get just a little bit of additional ground clearance on a stock SR5. Since my understanding of Tacomas is admittedly weak, I'm looking for guidance.
    my sense is that I can get just a little bit of additional ground clearance by swapping out the factory shocks for Bilstein 5100s and setting it at 0.85. Will that maneuver alone achieve the goal of getting just a little bit of additional ground clearance or do I need to get AALs, 18" wheels, whatever?
    thanks. Looking forward to getting 98% jokes at my expense, which is fine if the remaining 2% is solid info.
  2. Nov 4, 2015 at 7:22 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    Remove the front air dam. Boom. More clearance.
    Jokes aside, the Billies will give you an extra inch up front on the first perch. It'll give you a leveled stance front to back and that sounds like what you're looking for. You could get a cheap block for the back too if you want to lift the whole truck an inch
    Arailt likes this.
  3. Nov 4, 2015 at 7:23 PM
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    It's actually very simple. A 2" bigger tire.
  4. Nov 4, 2015 at 7:24 PM
    redbull9944
    Southwestern PA
    ^Could also do this. That'll be a 33 inch and you'll most likely have some rubbage though...
  5. Nov 4, 2015 at 7:26 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    ^this^
    Only way is to get tires that are 2 inches taller. Not sure what stock height is but you can probable fit 255/75/17 or 255/80/16 on stock suspension those are 32" tires
    Derek G likes this.
  6. Nov 4, 2015 at 7:29 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Bilsteins set at .85 will give you the most cost effective "correct" way of gaining 1" clearance up front.
    Arailt, numbah57 and Derek G like this.
  7. Nov 4, 2015 at 7:31 PM
    Derek G
    Silverton CO
    2016 TRD OR DC
    Ok my above post was the short answer, but the truth. Ground clearance is measured by the lowest point on a vehicles undercarriage, for is that would be the bottom of the rear differential. The only way to improve ground clearance is to add larger tires, and in many cases the best way to accomplish this is with a suspension lift. A two inch increase in tire diameter will give you a net of one inch increased ground clearance. Now, let's assume that the reason you want added ground clearance is to improve off-road capability. If that is the case I would suggest a suspension system that gets you adequate lift to clear 2 inch larger tires but is a proper suspension set up. If you just want it for looks and don't plan to do anything off-road then a spacer lift should be sufficient. If you plan on going off-road and want increased off-road performance then A coil over suspension system with an add a leaf in the rear or new rear leaf packs is the way you want to go.
  8. Nov 4, 2015 at 7:32 PM
    Derek G
    Silverton CO
    2016 TRD OR DC
    Skinny fo-eva!
  9. Nov 4, 2015 at 7:45 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    It depends what you mean by ground clearance
  10. Nov 4, 2015 at 8:20 PM
    pudge151
    Sean
    Connecticut
    This won't add any ground clearance. You need taller tires. And he can get taller tires without a lift
  11. Nov 4, 2015 at 8:34 PM
    Derek G
    Silverton CO
    2016 TRD OR DC
    He left himself an "out" he only said up front. :boink:Couldn't resist.
  12. Nov 4, 2015 at 8:44 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Yep, need to specify what you are actually after. Adding the 5100s up front will give you a little extra clearance as far as the front, skid plate area is concerned. It won't give you any extra clearance for the LCA or anything at the rear. That will require taller tires. What and where are you actually wanting more clearance, and how much is a little bit?
  13. Nov 4, 2015 at 9:23 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    portals.
    you should get portals on your new 2016 Tacoma
  14. Nov 4, 2015 at 9:36 PM
    pudge151
    Sean
    Connecticut
    yes
  15. Nov 4, 2015 at 9:40 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    60111d1343369581-portal-axles-131_1208_0_61a095534cef9cb933a4df0a61c8f3d242714c1d.jpg
  16. May 14, 2016 at 12:06 PM
    jeffreywanderson9
    jeffreywanderson9 Well-Known Member
    Jeff
    Portland Oregon
    2016 TRD OR DCLB Super White
    OME w/ dakars, Method NV 17", 275/70/17 Cooper AT3
    Hey guys hope you can help me out. I have a 2016 DCLB TRD offroad arriving in a week. I purchased a 2016 OME 2 inch lift in the medium load. I want to get the 255/80/17 Cooper STT MAXX's with method NV 8.5 inch wheels. Prior to the lift can they fit? After the lift should I have any issues? The place I am taking to get the lift said to stick with my stock UCA's for some reason.
