??Leather Seat install help Needed- Questions??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OmegaMan, Jan 16, 2010.
  1. Jan 16, 2010 at 5:14 PM
    OmegaMan
    OmegaMan [OP] Well-Known Member
    The Woodlands Tx
    2010 DC TRD Offroad
    Front window tint, Silver Star headlights and Fogs. Katzkin Leather Interior, Heated seats, UnderCover bed cover, JVC DVD HD radio + NAV
    I purchased the leather seat covers from Katzkin, and there are some "straps" on the inside of the front seats. Does anyone know what they are for?
    I figured they are for the airbag system but not sure exactly what.
    I would like some ideas before I tear into the seats.
    Thanks
  2. Jan 16, 2010 at 5:19 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I recently did my leather install but I need to see a pic of what you're talking about
  3. Jan 16, 2010 at 5:19 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    u prolly have straps for the back piece and the seat piece....the one set goes between the back/seat cushions and tie under the seat for tension on the covers. the others just wrap around and tie under the seat for the same reasons. i got a set of seat covers and they had the straps for this purpose. the bst way i saw to do it was remove the 4 bolts for the seat, pick it up and forward, then tilt the seat back and prop it on the DC seat so u can do everything w/both hands
  4. Jan 16, 2010 at 7:29 PM
    OmegaMan
    The Woodlands Tx
    2010 DC TRD Offroad
    Here are 2 pictures of the straps. There is also a "pocket" sewn into the cover.
    One buckle is black and one is white. They both have holes in them. The seat cover is turned inside out and the top of the cover is to the left of the picture.
  5. Jan 16, 2010 at 8:03 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Those straps go around the airbag - very important!!! When the bag deploys it shoots between those straps, splitting the trim and coming out of th seat next to you. Forget those straps and who knows where the bag will go!
    When you take the existing cover off, it will make sense.
  6. Jan 16, 2010 at 8:29 PM
    OmegaMan
    The Woodlands Tx
    2010 DC TRD Offroad
    That is what I thought. I have done leather seats in one of my vettes, but it did not have side airbags.
    I still need to get the hog ring pliers and rings before I start the job. The weather should be good tomorrow so I might start then.
    Thanks for the information.
  7. Jan 16, 2010 at 8:32 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Ya i just finished mine tonight and the straps are pretty straight forward once you get in there. One goes through a slit in the front of the seat and the other goes around the outside of the seat and they share a bolt on the back of the seat.
  8. Jan 16, 2010 at 9:07 PM
    OmegaMan
    The Woodlands Tx
    2010 DC TRD Offroad
    You should post some pics. I already did the head rest and the front pair sucked duck nuts.
  9. Jan 16, 2010 at 9:09 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    Ya i'll post pics tomorrow. Haven't put them back in the truck yet. The back seats were easy compared to the fronts. And yes the front headrests were a real bitch!
  10. Jan 16, 2010 at 10:07 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    The headrests: plastic bag and a shopvac shrinks the headrest, easily pull on the leather, turn off vac, pull out plastic.
    Easy.
  11. Jan 16, 2010 at 10:14 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    I actually used TY RAPS around the headrests in both directions. That shrunk it down enough to get the covers on then I cut the TY RAPS and pulled them out the bottom.
  12. Jan 17, 2010 at 5:24 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I've been thinking about heated leather seats...would be great to see a few pictures of your seat covers when you finish.
    Anyone else have pictures of their leather seatcovers?
  13. Jan 17, 2010 at 6:17 AM
    DLAV
    DLAV Well-Known Member
    Denis
    SK
    12 DCLB Barcelona Red
    N-Fab Steps, Weathertech floor mats, Oem Bed mat
  14. Jan 17, 2010 at 6:29 AM
    DLAV
    Denis
    SK
    here are a few pics of that strap going around the seat for the air bags. it's a little bit when you hook them up your seat is inside out so you have to allow for it to twist once when the cover is pulled over so that the sit flat against the seat cushion without any twists. i took pictures of everything as i took the old seats off so that i had a reference when putting the new ones on
  15. Jan 17, 2010 at 3:10 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
  16. Jan 17, 2010 at 4:00 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I did mine last March. This is the Liquicell leather that Toyota has installed. I bought the kit from another Tacoma owner who sold his truck before he had time to install it. I installed heat as well but still haven't permanently mounted the switches.
    Marc M
  17. Jan 18, 2010 at 3:13 AM
    saf023
    East Coast
    Very nice. Are you happy with the quality of the leather? Does it appear as if it will hold up better than the OE fabric?
    Thanks for posting the pictures. I'm going to have to look into Liquicell leather.
  18. Jan 18, 2010 at 8:29 AM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    It is definately a quality kit. It even came with pre-covered matching door panels.
    We are going on a year so far and there are no signs of wear on the driver seat which obviously gets the most use.
