Leave bed mat in during the winter?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cheapshades, Dec 16, 2020.
  1. Dec 16, 2020 at 3:31 PM
    cheapshades
    cheapshades [OP] Member
    2021 Black Tacoma SR5
    Planning to get an OEM bed mat for my 2021 Tacoma.
    Is it okay to leave in the bed mat during the winter/snowy months?
    I assume yes, and it's only a $100 part, but I wanted to see what others do.
    Thanks!
    SilverBulletII likes this.
  2. Dec 16, 2020 at 3:34 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    No problem keeping it in all winter. Makes removing hard icy snow easier actually as you can lift up on the mat to crack the snow apart. The mat itself is damn near indestructible.
  3. Dec 16, 2020 at 3:35 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    If its the oem rubber mat then yes.
  4. Dec 16, 2020 at 3:36 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I haven't removed mine in 10 years. I get down to zero and up to 110 degrees where I live. I actually bolted it down in front so the car wash doesn't blow it out.
  5. Dec 16, 2020 at 3:36 PM
    mhornco
    mhornco Well-Known Member
    Since the bed is not metal you don't have to worry about any moisture creating rust. Leave it in.
  6. Dec 16, 2020 at 4:06 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Yes. I've had mine in since 2016 and it's fine. I never thought about taking it out.
    Junkhead likes this.
  7. Dec 16, 2020 at 4:16 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I own a 14 year old '06 TRD OR AC with a bed mat that was removed once when I washed an accumulation of crud out of the bed. It was out for about an hour . Otherwise it stays in the bed. My '21 TRD OR AC also has a bed mat that'll likely be treated the same way. BTW, the mat in the '06 looks no different now than it did when brand new.
    Your biggest concern may be theft depending on where you live & travel.
  8. Dec 16, 2020 at 6:20 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Not a problem at all as my bed mat has been in my '96 Tacoma for 24 years.
  9. Dec 16, 2020 at 6:28 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a non-OE SB mat. Not problems here.
    With it, the Softopper, and some stuff stored back there, I no longer need to mess with tube sand in the slick stuff.
    shakerhood likes this.
  10. Dec 16, 2020 at 6:31 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Yes. Mine gets covered in dirt and bird poo and I give it a good hose down once in a while.
  11. Dec 16, 2020 at 8:16 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes,no problem
  12. Dec 16, 2020 at 8:20 PM
    Manwithoutaplan
    ID
    its rubber big shoots.
  13. Dec 16, 2020 at 8:37 PM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    You win.
    I was going to boast how my bed mat lived it's life in my Gen II and now it's in my Gen III, but that's only half as long as your. :)
  14. Dec 16, 2020 at 8:38 PM
    Shellshock
    Iowa
    Mine hasn’t come out since i got the truck except for the 2 times i washed out the bed.
    tonered likes this.
  15. Dec 17, 2020 at 6:18 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've always had bed mats or bed liners in 24/7 all year for years, never was an issue. Its even now better with the tonneau cover.
  16. Dec 17, 2020 at 7:00 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    and if you get stuck in mud or snow, use it under the wheels to get you out...
    TacoManOne likes this.
  17. Dec 17, 2020 at 7:13 AM
    bwag
    bwag Well-Known Member
    Brandon
    Hutto, TX
    2021 Cement TRD OR DCLB 4X4
