Leave DRL or lights on all the time?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soundchasr, Sep 11, 2019.
  1. Sep 11, 2019 at 8:46 AM
    Soundchasr
    Soundchasr [OP] Well-Known Member
    2020 Tacoma Sport MGM DC LB
    I like to drive with my DRL or regular lights on for safety. However, I have manual lights on my 2019 and I either forget to turn them on or to turn them off when I leave the car.
    I noticed that the lights will go out when I turn it off and leave. Is it ok to just leave them on all the time, i.e. keep the switch on when I leave the car for long periods of time?
    Thanks!
  2. Sep 11, 2019 at 9:45 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    No issues here with my SR5 switch left on DRL..the auto-OFF for me so I didnt care.
  3. Sep 11, 2019 at 9:48 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    You don't say which trim level you have, so we can't know for sure, but TRD and up have auto headlights / DRL. A pet peeve of mine is the way this is configured on the switch: It goes off -> auto -> drl -> on when it should be off -> drl -> on -> auto
    If you do have auto lights, then sure, leave em on all the time, the truck will figure it out BUT if you're a knuckle head like my neighbor, learn how to turn off your lights before backing into your driveway and blinding me in my living room at night.
  4. Sep 11, 2019 at 9:48 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    I have ocd... can’t leave anything working or running if I don’t actually need it... car on for more than 5 mins waiting for someone. Using lights in daylight, use my ac at max all the time... I can’t do it..
  5. Sep 11, 2019 at 9:49 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I leave my drl's on all the time.
  6. Sep 11, 2019 at 9:55 AM
    Soundchasr
    TRD Off-road. No auto on my stick.
    bbartol, ET340f and AKGSD like this.
  7. Sep 11, 2019 at 9:55 AM
    tcjacado
    tcjacado Well-Known Member
    You will be fine leaving them on all the time, the truck turns them off automatically.
  8. Sep 11, 2019 at 9:55 AM
    Soundchasr
    Even after you leave the car?
  9. Sep 11, 2019 at 9:56 AM
    GreyBaldTaco
    2019 F150 5.0
    Yep, I turn my lights on when I need them.
  10. Sep 11, 2019 at 10:01 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    I do have the tech and premium packages... I guess maybe that's the differentiator.
  11. Sep 11, 2019 at 10:02 AM
    tcjacado
    I do the same thing. It comes from a time of driving and owning cars and trucks that did not have auto shut off. Which was all of them:D except this one now.
    MtnFisher likes this.
  12. Sep 11, 2019 at 10:04 AM
    tcjacado
    There is no setting on the stalk/stick.... a ecu (computee board) controls them. When ignition is killed and power terminated, open the door and close the door and the lights go out.
    Soundchasr[OP] likes this.
  13. Sep 11, 2019 at 10:13 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    My '17 Sport has DRL, but no auto headlights. If I have headlights on, I have to manually turn them off, but if left in the DRL position, they turn off automatically. Of note, even if I leave my headlights on, they'll turn off eventually anyway.
    bbartol and Soundchasr[OP] like this.
  14. Sep 11, 2019 at 10:15 AM
    wahoobie
    chris
    Suffolk, VA
    My SR5 has not tech pkg and the lights go out after the setting times out. It's not when the doors close since I want them on a little longer and the customization is there.
    GreyBaldTaco and Soundchasr[OP] like this.
  15. Sep 11, 2019 at 10:21 AM
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    I read somewhere that it's not recommended to leave it in the 'on' position for more than a week on end without running the car.
    As far as what I do, like a few others have said here, I just leave mine in DRL mode. I only use the actual headlights when I actually need them. But mine does come with the headlight cut-off feature.
    Soundchasr[OP] and GreyBaldTaco like this.
  16. Sep 11, 2019 at 10:23 AM
    GreyBaldTaco
    2019 F150 5.0
    If you press your lock button 2 times they should turn off. Pressing 1 time delays them turning off but they do turn off.
    ChronicTaco, Yann, mtip and 1 other person like this.
  17. Sep 11, 2019 at 10:25 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    It's fine to do, but why? Put truck in Park, set parking brake, close moon roof, roll up windows, turn off lights, turn off radio, turn off heated seats, turn off climate system, turn off charger, turn off CB, now turn off engine. Start in upper left, work down to lower right. Get in the truck, turn on, then do all the items in reverse from lower right to upper left. Nothing get's missed that way.
    tacom08 and TartanEagle like this.
  18. Sep 11, 2019 at 10:25 AM
    johnnyroid
    Hmmm, thanks for that tip, I'll have to try that. I typically just touch the door handle to lock, but definitely want to check that out.
  19. Sep 11, 2019 at 10:27 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    My '17 SR has DRL, but not auto headlights. I have to manually turn off the headlights (no warning buzzer either, Grrr!). The DRL come on as soon as I release the parking brake and then turn off automatically with the ignition key.
  20. Sep 11, 2019 at 10:32 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If u accidentally leave your door cracked the headlights will stay on and kill your batt. I just turn mine off.
