Leave Heat Shield Off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by js312, Nov 22, 2015.
  1. Nov 22, 2015 at 11:20 AM
    js312
    js312 [OP] Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Crawled under the truck today to grease the driveshaft zerks and noticed one of my heat shields rattles. Tried to tighten the nuts down and snapped the studs right off the body. Had I realized that would happen I would have loosened them and added a washer. Because I snapped two out of the three off, I took the whole thing off because it can't hold itself up at that point.
    This is the shield on the passenger's side just behind the transfer case. I think it's the longest one under there. Should I try to reattach these studs somehow and put the shield back on or is it not worth the trouble?
  2. Nov 22, 2015 at 11:33 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Heat shields are generally good things. I'd source one from a junkyard if yours is not easily repaired.
    JDM likes this.
  3. Nov 22, 2015 at 11:36 AM
    js312
    Joe
    New England
    The shield itself is fine. The studs that attach to the body of the truck are no longer there. I have the studs, but not sure how to attempt to reattach them.
  4. Nov 22, 2015 at 11:37 AM
    T4RFTMFW
    Gotcha. Well I dunno then. How do the studs attach?
  5. Nov 22, 2015 at 11:40 AM
    js312
    Joe
    New England
    Looks like the studs were welded there, but with the tiny amount of force it took for them to snap off the body, I doubt it was actually weld.
  6. Nov 22, 2015 at 11:46 AM
    T4RFTMFW
    Got a pic of the remaining stud? And maybe of where the studs used to be?
  7. Nov 22, 2015 at 11:46 AM
    T4RFTMFW
    I assume you're out of warranty.
  8. Nov 22, 2015 at 12:39 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    use some JB Weld to reattach the stud
  9. Nov 22, 2015 at 12:56 PM
    js312
    Joe
    New England
    I will grab a picture tomorrow. I was thinking about JB Weld, just wasn't sure if it would be strong enough. Though wherever was holding it to begin with wasn't great so I am sure it couldn't be worse.
  10. Nov 22, 2015 at 1:08 PM
    DBF
    DBF Well-Known Member
    2012 Tacoma, 4x4.base model, access cab.
    Could it be welded back in place?
    shakerhood likes this.
  11. Nov 22, 2015 at 1:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    I've seen (on other marquees) SS hose clamps successfully used to mount the shield.
  12. Nov 22, 2015 at 11:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Go to a Good weld shop. They should have a Stud Gun to weld new studs in place. It should only take a few minutes and be fairly cheap. No idea as to the actual cost.
