Leaving E brake on in freezing temps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kidlin, Dec 27, 2021.
  1. Dec 27, 2021 at 8:41 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Simple answer is just don't use it if it is shitty out, I haven't lost my truck when i park it after 5 years now,
    really just dont use it unless your parking on a 25 deg road.
  2. Dec 27, 2021 at 8:47 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You won't harm that transmission pin. Especially on flat ground with the engine off. The real reason for the E-brake is for if your regular brakes go out or if you drive a manual. No real reason to set it in an automatic on flat ground.
    OmahTako and Kidlin[QUOTED][OP] like this.
  3. Dec 28, 2021 at 5:47 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I never use my E brake unless parked on a steep incline. Never used it during Winter months as I know it is a no-no for chances of freezing up here in the Great North but I do put it on and off just to keep it from seizing up.Just saying
    OmahTako, Kidlin[OP] and wiljayhi like this.
  4. Dec 28, 2021 at 7:01 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    My experience is... it depends. This is based on my old rides ('78 Buick; '89 Olds; '06 Escape).
    When I went driving in wet winter weather (cold rain, wet snow, melting snow), and I knew the temperature was going to drop below freezing, I'd avoid applying the parking brake to prevent the brakes from freezing up. Water gets sprayed up into the nooks and crannies and when the sun goes down, the temperature drops, and the cable / brake would get frozen into place. (First experienced with the '78, and pretty much when I pulled the handle, the e-brake pedal wouldn't come up..
    If the underside of your ride is dry, go ahead and put the brake on.
    If the underside is wet, avoid doing it unless you have no choice (i.e. - you're parking on a hill...)
    Kidlin[QUOTED][OP] likes this.
  5. Dec 30, 2021 at 10:19 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes, they salt and brine the roads lie crazy. You go for a drive and the truck is covered in salt.
  6. Dec 30, 2021 at 10:38 AM
    TheWhole9Yards
    TheWhole9Yards Well-Known Member
    I use the park brake every night when I park in my steep driveway. Wet, dry, hot or -45C never had it freeze or seize.
    Junkhead and willie2 like this.
  7. Dec 30, 2021 at 10:44 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    am i missing something, or whats the issue with the parking brake and car washes?
    Junkhead likes this.
  8. Dec 30, 2021 at 10:45 AM
    TheWhole9Yards
    there isn’t one.
  9. Dec 30, 2021 at 1:26 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    There IS an issue. water gets into the brake assembly and causes the brake shoes to "stick" to the drum. It happens randomly when I wash my truck and happens weather it is above or below freezing.
    The solution is to not use the e brake after washing until the truck has been driven enough to dry things out.
  10. Dec 30, 2021 at 1:36 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    The issues is parking brake and car washes plus freezing temperatures.
  11. Dec 30, 2021 at 1:37 PM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    You've had it happen above freezing? This doesn't make much sense to me unless you've got a rusty mess going on somewhere.
  12. Dec 30, 2021 at 1:41 PM
    DarthPow
    oh ok, I was confused why taking it through a car wash would create any issues.
  13. Dec 30, 2021 at 1:59 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Concern: OP is asking about e-brake sticking in below freezing temperatures
    Root cause(s): possibility (1) rear brake shoes sticking to the rear drums once engaged by the e-brake - moisture and freezing temperatures may cause the shoes to stick to the drums (2) @lostMarbles pointed out below that it isn't the drums that freeze it is the line that freezes and the spring is not strong enough to break it free
    Remedy: if concerned leave the car in park without the ebrake applied (only where safe to do so - no steep inclines), if the ebrake must be engaged you can free up the frozen brakes using 4LO and rocking back and forth
    Moisture can get into the drums if an owner frequently washes the rig in the wintertime (removing salt + sand), driving in rain or slush then temps dip down to freezing, or any other situation where moisture and freezing temps exist. The car wash comment was about introducing moisture in freezing conditions.
    DarthPow[QUOTED] likes this.
  14. Dec 30, 2021 at 2:05 PM
    DarthPow
    yea it took a bit to click. I didn't recognize that people were talking about washing their trucks in freezing temps... sorry, its been a long, slow day at work haha
    mic_sierra[QUOTED] likes this.
  15. Dec 30, 2021 at 2:06 PM
    #35
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Never had a problem myself
  16. Dec 30, 2021 at 2:19 PM
    #36
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Apparently there is but I’ve never experienced it, even after washing the undercarriage almost daily in winters.
  17. Dec 30, 2021 at 3:28 PM
    #37
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    The cable freezes (not the drums) and the springs are not strong enough to break it free. Put the hand brake down and give it a solid yank and it comes free. This was true on my 1st gen and is true on my 3rd gen as well.
  18. Dec 31, 2021 at 5:32 AM
    #38
    RichVT
    Rich
    Northern Vermont
    I have pulled my drums after washing the truck and have personally seen water in the drums. There doesn't seem to be any correlation between how I wash it and water getting in. And the problem is not the cold. I think it might be related to the type of material used for the linings on the shoes. Maybe different productions runs have different compositions of the linings which would explain why some of us have this problem and others don't.
  19. Dec 31, 2021 at 5:36 AM
    #39
    Montana_Actual
    Montana_Actual ;)
    Actually this morning my brakes were froze too. Just crappy weather. Starting to wonder if I'd fair better in a drier climate that's cheaper.... like Oklahoma. Dry enough anyways... Saw snow there when I was a kid but not negative temps for months. Everytime I go outside I just have to stand in the door way for 1 minute contemplating life choices while I acclimate.
    I dunno, I saw you can do a brake conversion and that intrigues me. The price doesn't, but the work does.
  20. Jan 2, 2022 at 6:54 PM
    #40
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Washing Tacosha at local self service wand wash and outside temperature is below -20C, (any temp below 0), following one simple rule: drive few blocks around, braking
    erratically and often, dry your rear brakes. Brake shoes and drums became warm, drying and there is no water to freeze between surfaces. Learn this lesson long ago with
    parking brake pads of my Volvo 740, no any problem since then.
