LED Accent lighting help...
Discussion in 'Lighting' started by df9334, Feb 28, 2013.
  1. Feb 28, 2013 at 4:48 PM
    df9334
    df9334 [OP] Member
    Dave
    Jacksonville, FL
    2011 PreRunner TRD Sport
    I am installing a couple of led strips inside the cab. one is going just below the radio; just over the top of the aux plug outlet over the cubby hole. The other is going to the rear of the inverter to light up the floor in the backseat area. I would like to hook them up so that they power up when I turn my parking lights and headlights on. Any suggestions as to which fuse I should hook them up? I'm thinking the parking light/license plate light fuse behind the lower left dash. Thank you in advance for the assistance.
  2. Feb 28, 2013 at 4:51 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    "add a fuse" to the parking light fuse (a 10A) and youre golden :thumbsup:
