LED backup lights – direct replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Dec 16, 2013.
  1. Dec 16, 2013 at 8:01 AM
    NiceGuyEddie
    NiceGuyEddie [OP] Well-Known Member
    Chino, SoCal
    none yet
    Hi guys, I did a search but actually wound up more confused.
    Is there a direct replacement LED bulb for the backup lights? I am looking for more light and to improve the back-up camera.
    Hoping for a simple bulb replacement with no mods.
    In any case, new stuff is always coming out, so what’s the latest?[FONT=&quot][/FONT]
  2. Dec 16, 2013 at 8:34 AM
    NSEARCH
    NSEARCH Well-Known Member
    Lakeside Ca.
    Kingcoilover 700lb springs / bypass King Shocks / Bypass All-Pro UCA All-Pro Rear Leaf Pack All-Pro flip kit Timbree bump stops .... Method Racing Wheels 16x8 Cooper S/T MAXX 285x75x16 body chop by "Pelfreybilt" extended Stainless brake lines front & rear's breather mod .... "Pelfreybilt" front plate bumper / warn winch with wireless remote / Rigid Industries Floods "Pelfreybilt" full set of skids "Pelfreybilt" Rear plate bumper / hidden hitch / Rigid lndustries Diffused All-Pro EX. Sliders .... Weatherguard tool chest Aluminum black powder coat "Pelfreybilt" Highlift Jack mounting bracket / Shovel & Axe bracket spare tire bed mount All-Pro EX. Bed Rack ARB air compresser
    look up Jumpers Leds on this site he sells every light know to man
  3. Dec 16, 2013 at 8:39 AM
    sprocketgti3
    sprocketgti3 Well-Known Member
    Todd
    Sacramento CA
    Prerunner TRD
    TRD Air box TRD Exhaust Rear Swaybar Undercover Bed Cover Additional D-Ring rails installed, refab of oem rails. Steel Side bed lock box. 1" lift kit. Stainless Brake Lines Frt D-ring tie downs 12 VDC power port in rear bed Reinforced tailgate structure DRL cutout switch.
    Just a FYI. I have LED on my truck. They are brighter but with that if you have the b/up camera option, it tends to bleach out the view at night when other lighting is around(i.e. street lamp etc).
    Good luck.
  4. Dec 16, 2013 at 8:42 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Aren't the backup cameras IR sensitive? If so, you should look for an IR LED and add it somewhere seperate from the backup lights.
  5. Dec 18, 2013 at 5:58 PM
    RZChief90
    RZChief90 Well-Known Member
    Virginia Beach
    I was considering LED's for my backup lights also, but how bad does it effect the camera? Also, which LED's did you use? I was looking at the Recon brand. I saw another post on TW where someone replaced their reverse light bulbs with 30w halogens instead of LED's. I definitely want something brighter. Thanks.
  6. Dec 18, 2013 at 6:28 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Csjumper sells direct fit 800 lumen led reverse bulbs. Super duper bright back up lights.
    Btw infrared is what a tv remote uses you can't see it.
  7. Dec 18, 2013 at 8:01 PM
    baurat88
    baurat88 Well-Known Member
    California
    '14 DCLB 4x4 TRD Sport JBL NAV
    TRD skid, BAMF light bar, 20in double row LED bar
    I got replacement 194's off of ebay for the reverse. 300 lumens. Has SMDs all around and a bright projector SMD at the top shining right out of the lens. Great item. 6 bux for the pair.
