Led bar 126w harness?
Discussion in 'Lighting' started by Tcgator, Sep 7, 2014.
  1. Sep 12, 2014 at 12:32 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Pins 3 and 4 are your main "switch" on the OEM one you show. Pin 3 should get +12 Volts when you want to be able to turn the lights on. (this can be wired directly to battery or an accessory port/headlihgts/cig. lighter.) Use a fuse!
    Pin 4 should either go to the LED bar or to the relay if you have one AND to pin 1 if you want your switch to light up when on. (Or you can wire pin 1 separately or ignore it.)
    Pin 2 goes to chassis ground (sheet metal) or negative side of the battery.
  2. Sep 12, 2014 at 5:12 AM
    Tcgator
    Tcgator [OP] Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
    Sooo my illuminated switch has 3 wires. Black white and blue. And the oem has 4 wires. How do I go about wiring them together
  3. Sep 12, 2014 at 10:47 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I explained above...
    How do you want your LED on your switch to work? LED on when LED bar is on? If so, connect pin 1 to the wire going from pin 4 to your led bar.
    EDIT
    Take a picture of the whole wiring harness if you need better directions.
  4. Sep 12, 2014 at 4:23 PM
    Tcgator
    Tyler
    Fernandina beach
    Well I got the wiring down. The only problem I have.. Is trying to mount it on the bull bar. Ugh can't drill through it
  5. Sep 12, 2014 at 4:45 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why does a 10 amp circuit have a 30 amp fuse?
