LED BAR QUESTIONS
Discussion in 'Lighting' started by Tjkearney33, Dec 27, 2014.
  1. Dec 27, 2014 at 8:56 PM
    Tjkearney33
    Tjkearney33 [OP] Well-Known Member
    Georgia
    2013 XSP-X
    No water leaks or anything? Pictures?
  2. Dec 27, 2014 at 8:59 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Not a single leak. Comes with a year warranty if they do. But i have yet to read one bad review.
    On my truck
    Their website
  3. Dec 27, 2014 at 9:10 PM
    Tjkearney33
    Georgia
    2013 XSP-X
    wow thanks for that info i can now come close to buying one from mike just $20 away. Ill let you know if i have any more questions.
  4. Jan 26, 2015 at 7:58 PM
    dscott7
    dscott7 Well-Known Member
    Anchorage
    2014 TRD Offroad DCSB
    Is that the rigid bracket that comes with the light or is it another one?
  5. Jan 26, 2015 at 9:04 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    The bracket and light bar are from two different companies.
  6. Jan 28, 2015 at 10:44 AM
    dscott7
    Anchorage
    The diagram isn't showing up for me. Do you have a mirror? I bought the rigid e2 30 inch lightbar but I also have a switch that should fit in the center console blanks.
  7. Jan 28, 2015 at 10:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2 on Avec light bars. Mike is great to deal with and I've had good luck with his products. I have a 30" bar and a pair of pods, no leaks or issues with any of them. I had Rigid stuff in the past and did not notice any difference when I replaced my Rigid lights with Avec. I actually felt like the wiring harness from Avec was much better, the Rigid one just felt cheap and did not come protected with wire loom (Avec's does). The switch, fuse holder and relay seemed similar on both.
  8. Jan 28, 2015 at 10:49 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    It seems like the original picture is gone? What do you mean a mirror? Rear view mirrors?
  9. Jan 28, 2015 at 10:50 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    I agree on the harness!
  10. Jan 28, 2015 at 4:46 PM
    dscott7
    Anchorage
    Sorry, I meant mirror like an alternate link.
  11. Jan 28, 2015 at 7:19 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    I cant' find the original picture but I can still help ya!
  12. Jan 29, 2015 at 9:21 AM
    dscott7
    Anchorage
    I bought a Rigid Industries E2 30 inch lightbar and I bought an Air of Board switch for the center console. The wiring from the AoB switch doesn't seem to be the same as the wiring for the switch that came with the lightbar. My plan at this point is to wire the lightbar straight to the switch and not to use the high beams as a second requirement (aka high beams must be on and switch must be pushed, instead it will just be switch has to be pushed).
  13. Jan 29, 2015 at 9:32 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    Do you have a picture of the switch or a diagram of it?
  14. Jan 29, 2015 at 9:37 AM
    dscott7
    Anchorage
    I think the wiring is like this. The diagram and wiring are in my truck right now, I'll grab a picture of it after work (4-5pm alaska time)
  15. Jan 29, 2015 at 5:43 PM
    #35
    dscott7
    Anchorage
    Here is the back of the switch my lightbar came with:
    Here is the wiring for the new switch I'm hoping to use:
    Here is the wiring from the lightbar:
    I see 4 wires for the switch I bought and 3 prongs from the switch that it came with.
  16. Jan 30, 2015 at 12:15 PM
    #36
    dan the taco man
    dan the taco man Member
    Dan
    Anchorage, AK and Gunnison, CO
    09' SR5 2.7L 4-Cyl
    Hey gym, would you mind giving me some assistance as well? I just got a very similar setup as dscott, with a small change. My OEM style switch only has three wires coming from the switch, so I shouldn't have a problem matching them up.
    My question concerns the difference in gauges between the wires. The wire harness has 20 AWG wire to the switch, but the OEM switch uses very small wire (high gauge as seen in dscott's picture). My harness has an inline fuse and a relay, which from my understanding makes it so that the current from the light bar doesn't actually run through switch. So my question is, will the tiny wire from my OEM switch overload if I connect them to the switch wires on the wire harness switch? I'd like to avoid ruining a $40 switch :D
    Thanks
  17. Jan 30, 2015 at 12:29 PM
    #37
    TRSJimmy
    Jimmy
    Gainesville, GA
    I see. The problem is, I don't know what wire is what on your switch without a diagram cause I have no clue what the green and blue wire is.
  18. Jan 30, 2015 at 12:31 PM
    #38
    TRSJimmy
    Jimmy
    Gainesville, GA
    I can't help you there Dan. I have no idea and I can't tell you something that's not true and have you mess up your electrical! I'm sure Skygear can help! He's the electric guru here!
  19. Jan 30, 2015 at 12:57 PM
    #39
    dscott7
    Anchorage
    Alright, I'll take a picture of the wiring diagrams after work.
  20. Jan 31, 2015 at 10:20 AM
    #40
    dscott7
    Anchorage
    Here is the wiring diagram for the lightbar:
    Here is the wiring diagram for the switch:
    Also it seems that the gauge on the wiring is different, is that an issue? Do I just use wire strippers to cut the ends off the bar's wires and attach the switches wires and then put electrical tape over them or what?
