LED bar Wiring Harness Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hrmancha20, May 4, 2016.
  1. May 4, 2016 at 5:00 PM
    hrmancha20
    hrmancha20 [OP] Active Member
    08 Tacoma TRD Sport
    just purchased a LED bar and harness. Trying to figure out where/how do I run the switch from under the hood to inside the cab? Any help would be great.
  2. May 4, 2016 at 5:16 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    One option is the Rubber grommet above left foot driver side. You can also see it under hood on firewall (on right side ) I used long toothpick taped to my wires and ran through that way.
  3. May 5, 2016 at 3:45 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    There's a little nipple you can cutoff at the gourmet so you can pass the wires through
  4. May 5, 2016 at 3:58 AM
    ChemDawg
    Maine
    2005 sr5 4x4
  5. May 5, 2016 at 3:59 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Charpen a piece of coat hanger wire and pierce the outside of the grommet away from the large wire bundle. Push barbed pins back out of connector, mark their positions. Tape the wire to the coathanger and pull back through the grommet. This will make a tight fit around the wire and won't leak. Redo your connector and done.
  6. May 5, 2016 at 4:00 AM
    rutacoma
    rutacoma Well-Known Member
    OK
    2012 TX TRD DCSB
    straighten out a metal coat hangar, pop in through the grommet, hook the other end around the end of your harness. put some electrical tape around it with a pea sized dab of grease and itll pop right thru. done this MANY times
  7. May 5, 2016 at 6:08 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    Careful with metal..:eek: :D wood and plastic dowels help to not damage stock wiring (read that here on tacomaworld before I ran my wires):thumbsup:
  8. May 5, 2016 at 6:29 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
  9. May 5, 2016 at 7:23 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I know in my experience the little nipple on the main firewall harness grommet was way the hell up underneath everything and basically clamped off by the main harness. I had a hell of a time running a 8gauge wire through that thing. On my most recent wiring project I opted for the grommet near the brake system/brake booster as seen in the thread @ChemDawg linked above. Way easier, you just have to cut a whole into the grommet to run your wires. It pops out through some carpet liner on the inside of the cab right behind the steering column basically.
