LED bar wiring issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalex, Sep 13, 2016.
  1. Sep 13, 2016 at 4:39 PM
    Nalex
    Nalex [OP] Well-Known Member
    2012 Tacoma DC TRD OffRoad
    hi all,
    I installed an LED bar on my Tacoma. Everything went well but I want to replace the switch that came with the light with another that will fit in the middle console.
    The original had 3 wires and the replacement has 4 wires.
    Any idea where the wires suppose to go?
  2. Sep 13, 2016 at 4:42 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    MicTuning has wiring diagrams available online.
  3. Sep 13, 2016 at 4:43 PM
    T4RFTMFW
  4. Sep 13, 2016 at 4:44 PM
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Double check with a voltmeter to make sure, but it looks like it's white to red next to green, blue to green, and black to black. Orange I believe is an illumination cable.
  5. Sep 13, 2016 at 4:51 PM
    Nalex
    Thanks for the quick response. Mine is coming directly from the battery so I guess I will leave the red (2) unconnected.
  6. Sep 13, 2016 at 5:06 PM
    Nalex
    Ok, so I put the black on the black duhh
    Red(1) on the white and green with red (2) together on the blue. See pic 1
    What I have now
    Pic 2 when the light is off
    Pic 3 when the light is on
    Since it is directly from the battery I will always have power even if the car is off.
    Will this set up drain the battery? the small light will be on all the time.
  7. Sep 13, 2016 at 6:48 PM
    perpetualenigma3
    Mr.
    An led at that low of a wattage should drain your battery before you drive your truck assuming you drive it every day. Now if it sat for months then yes you'd eventually drain the battery, but a few hours over night is more of a nusense than taxing on the battery. You could just run your 2nd red wire to an illumination source (ex: illumination for the cluster) and just tap it in using one of these.t-taps.jpg 7693846-23.jpg
  8. Sep 14, 2016 at 2:43 PM
    Nalex
    Update:
    So after few tries: black on black (ground), 1st red on the blue (power out), and green on white (power in). This will leave the 2nd red which is for switch illumination.
    This empty fuse slot has +12v when light is on. So I used it to supply the switch illumination.
    Switch light is off when car is off.
    And on as this pic when parking light or head lights are on.
    image.jpg Headlights and LED bar are on.
    Thanks for your help.
