LED Bed Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by minuteman, Apr 2, 2013.
  1. Apr 2, 2013 at 10:03 AM
    minuteman
    minuteman [OP] Member
    n
    So I wanted to wanted to light up my bed at night so I could see what is in it. I looked around at kits and for what they cost and how crappy they were I decided it was best to come up with my own solution.
    I first bought a BlueSea fuse box with a 100amp breaker and wired it in like so many of you have done before. I then ordered 16 feet of HitLights Waterproof LED Ribbon from Amazon for $15.99. They attach to the bed rail with 3M tape that came already on the LED's. I cut them to fit under the lip of the bed rail and used 14ga wire between rails to run power.
    http://i.cdn2.tacomaworld.com/forum/images/attach/jpg.gif
    Now, I didnt want to go with a switch that didnt look right in the truck. I found this scion switch. Looks good and only needed a little work to get it to fit.
    The tough parts was running the wires through the fire wall and to the back of the truck. I grounded the switch to the fuse box and the LED's to the back of the bed. I found heat shrink to be my best friend.
    The whole project cost me about $100 which was cheaper then any kit, gives off more light then any kit, and I got a fuse box to run my other accessories.
  2. Apr 2, 2013 at 11:05 AM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    Looks good. I've been thinking of doing this. I did cheap driving lights in my old truck in the side pockets. But I like the clean look of led's. Is it possible to just use an inline fuse like with the cheap driving lights or is the fuse block a must?
  3. Apr 2, 2013 at 11:11 AM
    minuteman
    n
    You can really use anything (inline fuse, add a fuse, etc.). The draw is extremely low. I opted for the fuse box cause I'm going to be adding some off road lights soon and I wanted to keep the wiring as clean as possible. I didnt do that in my old truck and I had wires just going every where. It was an awful mess.
  4. Apr 2, 2013 at 11:15 AM
    aj hank
    aj hank Well-Known Member
    AJ
    412 PA
    09 Regular cab
    Hi/lo HIDs, window tint, keyless entry
    nice build-a-kit. that looks pretty sweet and definitely a cool idea for a reasonable price
  5. Apr 2, 2013 at 11:16 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    I have the same fuse panel and breaker waiting to go in.
    Side note: What size bolts did you use to bolt that panel to the body?
  6. Apr 2, 2013 at 11:26 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I have 15 feet of LED light strip that only pulls 2 amps. There are a few good how to's in the lighting section. I'd like to do something like this with the hood, bed, and door lights:
    http://www.tacomaworld.com/forum/lighting/267483-led-lights-under-truck-2.html#post6591525
    Good job OP!
  7. Apr 2, 2013 at 10:17 PM
    minuteman
    n
    I couldnt even tell you what size bolts they are. I just happened to come across them in the garage and they fit perfectly.
  8. Apr 2, 2013 at 10:18 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Scubbed
  9. Apr 2, 2013 at 11:30 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    sub'd
  10. Apr 2, 2013 at 11:34 PM
    Hoozel
    Hoozel Well-Known Member
    Ty
    Edmonton AB
    very, very nice job !
  11. Apr 22, 2013 at 1:22 PM
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    Looks good man! I just did my own, and wired it to a contact switch. When the tailgate is dropped down... the lights turn on... when it's up.... they go off.....
    What size fuse did you use for the bed lights????
  12. Apr 23, 2013 at 7:24 AM
    Zonktified
    Zonktified Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
  13. Apr 23, 2013 at 10:28 PM
    minuteman
    n
    I'm using a 15amp fuses for the time being because that what I have on hand at the moment. Its a 24 WATT ribbon so you would only need a 2 amp fuse.
  14. Apr 23, 2013 at 10:39 PM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Looking great! :thumbsup: Very clean!
