LED bed lights
Discussion in 'Lighting' started by belone12, May 13, 2013.
  1. May 13, 2013 at 7:53 AM
    belone12
    belone12 [OP] Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    Starting the bed light mod. Quick question, is there any reason I can't think of that mounting the switch inside this cubby is a bad idea? Way I see it I is protected from the elements and out of sight/reach of some accidentally turning it on....
  2. May 13, 2013 at 11:22 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That cubby still sees some water/dirt, hence the drain holes. Use an outdoor switch.
  3. May 13, 2013 at 11:41 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2 Won't be buried in snow or under water, but still will be exposed to a good amount of moisture.
  4. May 13, 2013 at 1:00 PM
    belone12
    Brian
    Long Island, NY
    Ok cool. I mounted it elsewhere and will sow later (I also have a tonneau which helps) but after thinking I was finished, no lights. Very simple wiring: battery to in line fuse (10amp) to the switch. Red + on LEDs to the switch. Black - on LEDs to ground in tail light cubby. Reconnect battery = no lights. I cut the LEDs in between the set (every 3rd), am I supposed to do something to them after thAt? I know pictures would help...
  5. May 13, 2013 at 1:25 PM
    belone12
    Brian
    Long Island, NY
    If the switch only has 2 wires (both are black and not labeled) does it matter which one is connected to the battery vs the lights?
    Thanks
  6. May 13, 2013 at 1:51 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    No it doesn't matter which way your switch was connected. You said you grounded the lights inside the cubby.... The cubby is plastic which means its not ground. Check to make sure you grounded he lights to a solid metal point which contacts the frame by metal in some way or another.
  7. May 13, 2013 at 1:53 PM
    ProForce
    Anthony
    Alaska
    Double check your fuse, even if its brand new. They go bad easily. Also verify you connected it to the positive side of the battery and not the negative side. Sounds like a stupid mistake, but trust me, some people make the little mistakes.
  8. May 13, 2013 at 1:54 PM
    ProForce
    Anthony
    Alaska
    Need a tester of some sort, like a digital multi meter to verify that power is actually reaching the switch. If it is, make sure its actually passing through the switch when its turned on.
  9. May 13, 2013 at 1:58 PM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I think Led's don't light if current is run the wrong way through them.
  10. May 13, 2013 at 2:00 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    This... Leds don't turn on if you dont wire them correctly (+) and (-)...
  11. May 13, 2013 at 2:01 PM
    belone12
    Brian
    Long Island, NY
    Thanks guys. Battery is properly connected, fuse is solid, I just ran down to west marine and picked p another switch. See if that works. If not I will go to my mechanic and see if he can test the power running through it. Appreciate the help (as always)
  12. May 13, 2013 at 3:23 PM
    belone12
    Brian
    Long Island, NY
    image.jpgWell, I just redid all the connections. I cannot for the life of me figure out what's up. maybe one of two things:
    1) cut the led in the wrong place? Would that kill the strip?
    2) bad ground?
    If anyone has some input, I appreciate it. I really thought this would be awake walk, ugh
  13. May 13, 2013 at 3:25 PM
    belone12
    Brian
    Long Island, NY
    Now I can't upload multiple pics for some reason
  14. May 13, 2013 at 3:26 PM
    belone12
    Brian
    Long Island, NY
    Grounded behind he tail light
  15. May 13, 2013 at 5:50 PM
    belone12
    Brian
    Long Island, NY
    Good to go, took a dinner break, reset the ground wire, and plenty o light. Sorry to be a psycho before, frustration took over. Thanks for the input
  16. May 14, 2013 at 5:11 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Looks Great!!
  17. May 14, 2013 at 8:29 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Nice! Well done!!!
