LED blinker question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImpulsedComa, Apr 28, 2016.
  1. Apr 28, 2016 at 7:43 AM
    ImpulsedComa
    ImpulsedComa [OP] Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    I want to get led's for my dtrl/blinker bulbs and I dont want to tap resistors into stock wiring. Do they make an extension harness i could plug into the stock socket and just tap into the extension with the led resistor? The end of the harness would accept the led bulb and have to turn and lock into the holding socket...
  2. Apr 28, 2016 at 8:17 AM
    ImpulsedComa
    NJ
  3. Apr 28, 2016 at 2:04 PM
    ImpulsedComa
    NJ
    anybody ever use something like this?
  4. Apr 29, 2016 at 6:25 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Haven't used them, but that link doesn't say if they are compatible with the 3157 CK bulbs. The CK are wired a little different I believe.
  5. Apr 29, 2016 at 10:07 AM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    The resistors have beefy looking heat sinks.
    I've thought about this too. I have LED brake lights; it kind of bugs me that the blinkers are incandescent. o_O
  6. Apr 29, 2016 at 10:16 AM
    ImpulsedComa
    NJ
    Yep, these wont work. My harness has 4 slots to grab and turn when you secure the socket to the back of the headlight and these have 3... I might do the 12 pin shave the resistor mod and call it a day if i cant find the right harness. There has to be one out there
  7. Apr 29, 2016 at 10:18 AM
    Silence9
    Alberta, Canada
    I'll keep my eyes open and let you know what I come up with. I want to do this mod as well.
  8. Apr 29, 2016 at 10:19 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    15 TRD Sport 4x4 DCLB Stormtrooper
    Bilstein 6112/5160 17" Matte black TRD wheels KO2s Window tint all the way around Relentless Fab tailgate reinforcement Wet Okoles front and back TRD leather shift knob Various LED replacement lights Painted keyhole cover by key techniques Black Headlight Mod (BHLM) Entune screen protector OEM bed mat TRD exhaust RCI IFS skid
    Why don't you want to use resistors?
  9. Apr 29, 2016 at 10:20 AM
    ImpulsedComa
    NJ
    ill let you know as well if i come up with anything
  10. Apr 29, 2016 at 10:21 AM
    ImpulsedComa
    NJ
    i just dont want to tap into stock wiring...
  11. Apr 30, 2016 at 8:07 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Is full synthetic blinker fluid required with LED bulbs replacing 3157 CK's?
  12. Apr 30, 2016 at 8:43 AM
    ISLANDJIM
    ISLANDJIM Well-Known Member
    2017 4Runner Off Road
    That's a big NO, but it is recommended. and once you go synthetic, you can never go back!
  13. May 4, 2016 at 6:24 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Note that companies such as VLEDS don't recommend regular replacement bulbs such as 3157ck as a DTRL bulb. They used to, but no longer. Too much heat running on high brightness full time in the closed space. If you really want, choose the VLEDS Triton system or similar. Twice the Price but you want it to last. Agree on not modifying stock wiring.
  14. May 4, 2016 at 6:29 PM
    ImpulsedComa
    NJ
    I was thinking of a bulb like this that is only 11watts... I was going to convert it from standard to srck type and use it as my dtrl/blinker. I didnt think 11 watts would be that hot even as a dtrl... Now im not sure, am i wrong?
    http://www.ebay.com/itm/CREE-LED-MI...NE-BULB-HIGH-STOP-REVERSE-LIGHT-/131539854630
    or this one, 5 watts
    http://www.ebay.com/itm/CREE-LED-MI...-BULB-BACK-UP-TURN-SIGNAL-LIGHT-/141697750595
