LED Bulb issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbell92129, Mar 17, 2018.
  1. Mar 17, 2018 at 1:14 PM
    cbell92129
    cbell92129 [OP] Active Member
    2012 Toyota Tacoma Pre Runner Texas Edition
    Bilstein 5100 all around, 34” Falken Wildpeak tires, Bed Cover, Flow Master exhaust, K&N filter, throttle body spacer, de-badged, rugged ridge fenders, Total Chaos upper and lower control arms, ICON coilovers
    Sorry if this is a re-post, but I replaced the running lights with LEDs today and they worked for a few minutes and then stopped working as running lights and only work as turn signals. I checked the fuses and they look fine. Wondering if it might be a relay issue....
    I also put the old bulbs back in and they don’t work as running lights anymore either...only turn signals.
    Anyone else experience this before?
  2. Mar 17, 2018 at 1:15 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Mar 17, 2018 at 2:41 PM
    cbell92129
    Ok so, everything is working now...returning the LEDs...
  4. Mar 17, 2018 at 2:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    What was the problem?
  5. Mar 17, 2018 at 2:52 PM
    cbell92129
    I installed LED turn signal/running light bulbs and they worked briefly then stopped working as running lights, only worked as turn signals.
    I checked the fuses, no issues. Installed the stock bulbs back in and at first they only worked as turn signals, now they’re working as expected as both running lights/turn signals.
    Should’ve just left them alone to begin with.
  6. Mar 17, 2018 at 3:00 PM
    Muddinfun
    That's strange.
    FWIW, I wouldn't buy LEDs from any of the local auto parts stores. I buy most of mine from JDMastar.
  7. Mar 17, 2018 at 3:03 PM
    cbell92129
    Thanks, yeah Amazon purchase. Doesn’t surprise me that it’s odd, I usually have odd sh*t like this happen.
  8. Mar 18, 2018 at 7:19 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LED Conversions are mostly a pain in the ass and not worth the effort. IMO
    CMD-KY likes this.
  9. Mar 18, 2018 at 8:12 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Generally true, but everyone seems to want to have them. I think the biggest problem is the large number of cheap Chinese products out there. They ruin the market for the relatively few good LED manufacturers. Like many other things, you get what you pay for.
    crashnburn80 likes this.
  10. Mar 18, 2018 at 11:19 AM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    The only LED change that looks good to me is higher output reverse lights.
  11. Mar 18, 2018 at 5:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That would be one good use. But I would wire dedicated LED Lights instead of converting the existing lamps.
    CMD-KY[QUOTED] likes this.
  12. Mar 18, 2018 at 6:20 PM
    Too Stroked
    Tom
