LED bulb numbers from superbrightled.com
Discussion in 'Lighting' started by tomash66, Jul 26, 2012.
  1. Jul 26, 2012 at 3:09 PM
    tomash66
    tomash66 [OP] Active Member
    I had found a write up a couple weeks ago that someone had posted the bulbs that they bought from superbrightled.com(with the part number) and now I cant find it anywhere. The reason Im not using the sites bulb finder is because i did that for my wifes car and got a wrong size bulb in the mail.
  2. Jul 26, 2012 at 3:14 PM
    Aw9d
    Aw9d That one guy
    Az
    Soooooooooo what bulbs are you wanting to replace?
  3. Jul 26, 2012 at 4:21 PM
    tomash66
    The post I had found had everything but the headlight and turn signals and id like to do the same I've already done the dome and map lights
  4. Jul 26, 2012 at 4:25 PM
    Aw9d
    Aw9d That one guy
    Az
  5. Jul 26, 2012 at 4:30 PM
    tomash66
    Do those match up with what's on superbrightlightleds.com?
  6. Jul 26, 2012 at 4:34 PM
    Aw9d
    Aw9d That one guy
    Az
    I would assume that they go by the same bulb types and numbers that the rest of the world uses. I'd check with them as I've never bought from their site.
  7. Jul 26, 2012 at 5:30 PM
    tomash66
    no its not the same on there site. that thread was helpful but the thread I had found earlier was a superbrightleds.com site specific one
  8. Aug 2, 2012 at 2:30 PM
    Aw9d
    Aw9d That one guy
    Az
    Um, not sure what you are looking at but everything was listed here and all the numbers pretty much match up.
    http://www.superbrightleds.com/vehicle_led_bulb_finder.php
  9. Aug 6, 2012 at 5:26 PM
    RipVanDango
    RipVanDango Active Member
    Cody
    Alaska
    '92 / 2012 TX Pro
    Leer 100XL Canopy, Home Made LED Bar, Lightforce Blitz 4300k 35W HIDs, Supertones Hella Horns, LED Bed Light,
    If you replace the dtrls make sure you get the bulbs with ck wiring. The regulars will blow one of two fuses connected to them.
