Led bulb or full replacement
Discussion in 'Lighting' started by mattblacklimited, Oct 19, 2019.
  1. Oct 19, 2019 at 12:28 PM
    mattblacklimited
    mattblacklimited [OP] New Member
    2017 Tacoma limited
    I’m looking to put led bulbs in my headlights and fog lights. Wondering if I should go with just led bulbs or replace the entire headlight and fog lights. If I just do bulbs for headlights will I have to do high beams and regular?
    Not sure how it all works, help a brother out.
  2. Oct 20, 2019 at 7:09 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum!
    Check out this thread for headlights:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    Note that most drop in LED headlights will not project correctly, and you will lose your projection distance. Most will show you lots of cleaver marketing to overlook the fact. The only one I have tested that has done better than stock at distance is Hikari ultra which is covered in post #1608. A basic Philips H9 halogen bulb swap will be higher performing, and the Morimoto XB LED headlight assemblies will do even better, and are the best method to run LEDs.
    The headlights run projectors, so glare isn't an issue. In the fogs, they are reflectors, which if using LEDs is going to cause significant glare and scatter. For the fogs you should replace the entire housing. Nearly all the LED fogs for a Tacoma are covered here:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    Best in class are Rigid selective yellow and KC G4 in white.
    I was thinking you are 3rd Gen, but realized you don't actually list your year. What year is your truck?
    grubburg likes this.
  3. Nov 10, 2019 at 7:21 AM
    mattblacklimited
    2017 Tacoma limited
    3rd generation 2017
  4. Nov 10, 2019 at 7:24 AM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I just ordered some morimoto HID kit from the retrofit source for $150. People seem really happy with theirs.
