LED Bulbs and Lane Change Module
Discussion in 'Lighting' started by H0LLYW00D, Oct 30, 2010.
  1. Oct 30, 2010 at 2:33 PM
    H0LLYW00D
    H0LLYW00D [OP] Well-Known Member
    I put in a set of LED replacement bulbs from Recon and I am having trouble with them after installing a new signal light module.
    The way the module works is you soft touch the signal light switch and it will flash the signals for 6 more times. With the LED bulbs in the module only flashes the insturment lights and the LEDs in the mirrors, but the front only work when you activate the signals all the way and the back dont work at all.
    When I put in the original bulbs the front and rear work normally but the fronts dont flash when i use the lane changer module.
    The front bulbs are a dual filliment bulb, not sure if this will make a difference or not.
    Anyone have any ideas? or questions that I should get answers to get the whole system to work with LEDs.
