LED bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sleevenspindle, Aug 4, 2011.
  1. Aug 4, 2011 at 4:59 AM
    sleevenspindle
    sleevenspindle [OP] New Member
    Tom
    Newtown CT
    08 TRD Sport Double Cab
    Bixenon Headlights HID fog lights DVD Navigation system with JBL dual 10" Stealth sub box
    Anyone replace any bulbs with LED's? I've replaced some lights, but after awhile the LED's start to flicker. Anyone know of any manufacturers that have bulbs that last longer? Love the look. I just hate how often I need to replace them. Thanks guys.
  2. Aug 4, 2011 at 5:15 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Where did you purchase them from?
  3. Aug 4, 2011 at 5:23 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    SuperBrightLEDs.com
  4. Aug 4, 2011 at 5:25 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    I have always bought mine from autolumination.com and they've lasted. Not sure if it's a voltage regulation thing or what.
  5. Aug 4, 2011 at 7:54 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    map lights, dome light, and license plate are all led from superbrightleds.com No flickering problems.
  6. Aug 4, 2011 at 8:02 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    mine are from superbrightleds as well... i got the amber 12led for the DTRL white leds for the map lights and a festoon led bulb for the dome... ive replaced my DTRL with a yellow bulb and my map and domes with LED panels, i can sell you my old ones if you want. nothing wrong with them
  7. Aug 4, 2011 at 8:15 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    LEDs should last a very long time. I replaced my maps, and dome with LED panels, and my LP lights with LED bulbs. No flickering except the dome when its dimming.
  8. Aug 4, 2011 at 1:47 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    I think you mean you swapped your parking lights instead of DTRL....did the 12 head version fit through that hole?? I mean I'm assuming they did since you put them in there but it had to be tight.
  9. Aug 4, 2011 at 2:37 PM
    AsianAnts
    AnT
    sir you are correct... i meant the parking lights... haha. and yup, it fitted thru the hole just fine
  10. Aug 4, 2011 at 5:31 PM
    FY01CPO
    FY01CPO Well-Known Member
    Jeremy
    CT
    SR5 4x4
    black tube steps, side marker turn signals, 15% tint and window strip, EGR vent shades, fighter pilot/cockpit mod, console and glove box auto on LED, anytime fog light mod, 3000k HID fogs, bed mat wing nut mod, locking bed storage bin mod, smoked tail lights, plasti-dipped rims, blacked out emblems, black tail pipe, tail gate hose clamp, rear seat utility/dog shelf with rear center console access door.
    DAMN! I was hoping you found something that wouldn't flicker in there. I don't want to mess with a relay or load resistor, etc. :(
    Anyway, I replaced my maps, dome, and license plate lights with LEDs I got off Amazon. They have all worked perfectly too! I also added LED lights for a "fighter pilot" mod and lights to the center console and glove box. They are in my gallery.
  11. Aug 5, 2011 at 5:43 AM
    sleevenspindle
    Tom
    Newtown CT
    Thanks for your quick responses guys. I bought mine off of Ebay. Probably one of those "you get what you pay for" things. I replaced my dome, map, brake, upper brake and license plate bulbs with LED's. The only ones that did not start to flicker was the dome. Had I known the 2009 Tacomas would have come with tail LED's I would have waited. Also they have that great charcoal color that they didn't make for the 2008's. Oh well. Thanks again.
  12. Aug 5, 2011 at 5:05 PM
    FY01CPO
    Jeremy
    CT
    SR5 4x4
    YES PLEASE!!
  13. Aug 5, 2011 at 8:49 PM
    reiss91
    reiss91 Well-Known Member
    Mark
    Mass
    2011 Tacoma Gray
    ive got a set of v-led switchback bulbs in my front DTRL/Turn Signal lights. Tapped 12v power from amber corner light that is on in position 1 and 2 of the light switch. Also had to wire in a Load Resistor in parralell with the LED to fix the hyper flash.
    White when the corner lights are on and they switch to amber and blink for turn signal. Also did Fog Light Mod and can have the fogs on anytime. Just with the lights off they will be on, in parking lights they will be on, high beam they are on.
    With my 55W 8K DDM headlights and 35W 8K fogs on at the same time I can literally see every thing vividly.
    Also I noticed the headlights seems lowered a little after switch to these bulbs up top. Maybe they modified the bulb to compensate for beam scatter? i definitely didn't adjust it.
  14. Dec 12, 2011 at 5:59 AM
    nevenelestate
    nevenelestate Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    What are the sizes? i want to swap out the map and dome bulbs
    **edit - SuperbrightLEDs.com has a handy dandy tool that tells you all the sizes :)
    here is the link for 2011 tacoma http://www.superbrightleds.com/vehicle/2011/toyota/tacoma/62/1052
    I too buy all my LED bulbs from superbright and have never had my issues, used them for my past three cars and my motorcycles :)
  15. Mar 9, 2015 at 7:22 PM
    NovaDogg
    NovaDogg Member
    Tyler Durden
    2015 TRD Sport 4x4 Manual
    Blacked out badges, carbon fiber interior accents, hardwired GPS and Radar Detector, black racing stripes
    I used these for my 2015 Tacoma and they work great. I got them both at Walmart.
  16. Mar 9, 2015 at 8:35 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    You know you can get these on eBay for a lot cheaper. Same bulb(s). Same performance, a lot less $$$. I'm running those in my Taco - have been for over 6 months with no issues so far.
  17. Mar 10, 2015 at 1:58 PM
    NovaDogg
    NovaDogg Member
    Tyler Durden
    That's good to know. I was already at Walmart so it was more convenient for me to pay $6 for the map bulbs and $8 for the dome light. No shipping and no waiting
