led bumper backup lights wiring help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by farmer_kyle, Jan 27, 2016.
  1. Jan 27, 2016 at 12:23 PM
    farmer_kyle
    farmer_kyle [OP] Well-Known Member
    2004 Tacoma sr5
    3.5" (adjusted to 4.5") fabtech suspension lift. 15x8 procomp 252 crawlers. 32x11.5 BFG Ko2's.
    hey guys. Since they don't make a wiring harness long enough for some flush mount rear bumper lights, should i just get the dual output wiring harness I want and use new wires to extend it? if so, what size/type of wire should i use? Thanks for your help
  2. Jan 27, 2016 at 2:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you know the wattage of the lights, divide that number by 12 (volts) to determine how many amps they will draw. Choosing the correct wire size is dependent on how many amps the wire can safely carry for the length of wire. There are other factors but that is the main one.
    Here is a chart for wire size capacities.
    skeezix and TashcomerTexas like this.
  3. Jan 27, 2016 at 2:14 PM
    SoCal_Yotas
    SoCal_Yotas Well-Known Member
    Elias
    Santa Clarita
    2015 Toyota Tacoma TRD-Sport 4x4
    Do you want them as strictly reverse lights? I wired mine directly to the reverse lights in my tail lights they work great and they pull so much less than the regulat bulbs so a relay and all that isn't necessary
  4. Jan 27, 2016 at 4:06 PM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    22-24 gauge wire will be plenty for led lights. Wire the red wires from the led lights to the red/black tracer wire and the black led wires to any good ground.
  5. Jan 28, 2016 at 12:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I just connected them to the stock reverse lights .
    I used 14 gauge wire because I have quite a bit and it handles most 12 VDC needs for me
  6. Jan 28, 2016 at 1:10 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah if you just want em as reverse lights just splice em into the existing wires.
    If you want em run independent with a switch and certain harness youre lookin at, just extend those wires just like you mentioned. Use the same guage wire as is supplied with the harness, itll prolly be 16 or 18 GA. Itll say what GA it is on the wires themselves when u get the harness.
    I personally use 14 GA like Wyoming09 does on about everything i do since i have a shit load of it myself.(well now im second guessing myself it may be 16GA) but reguardless as long as youre not using a teeny tiny GA wire it wont be a problem what size ya use really... a good rule is just to not use a smaller size than whats already used in the harness.
  7. Jan 28, 2016 at 4:43 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What type of lights do you have in mind - incandenscent, halogen, or led? And most important, what brand are you thinking about that you can mount flush into the rear bumper?
  8. Mar 11, 2018 at 10:09 AM
    guyross
    guyross Member
    Guy
    1999 Tacoma 4X4 Extended Cab
    I would like for my Rigid Dually flush rear bumper mount LED's to operate when the factory back up lights are engaged and also use the supplied harness to operates them independently. I don't see a problem with double feeding them. Any cautions our suggestions are welcomed.
  9. Mar 11, 2018 at 10:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    Since the thread you've posted in here is over 2 years old, you might get more assistance if you start your own.
    There's not a problem doing an 'either or' wiring scheme, as long as you know how to isolate the circuits so one doesn't back feed the other. Which an unplanned double feed will do.
  10. Mar 11, 2018 at 10:39 AM
    guyross
    guyross Member
    Guy
    I don’t know how I would isolate the circuits. Would a inline diode do?
  11. Mar 11, 2018 at 10:55 AM
    Clearwater Bill
    Billy
    Largo Florida
  12. Mar 14, 2018 at 5:52 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    You could always wire them with a harness to a relay, and use the wire that feeds the stock backup lights to trigger the relay, then wire a switch that will do the same thing. This is what Im planning to do. I have some flush mount led lights wired to the stock wiring harness at the moment, but would like to switch everything on when parked.
    guyross likes this.
  13. Mar 14, 2018 at 6:14 PM
    guyross
    guyross Member
    Guy
    That sounds great. I would need to draw a diagram. I can’t do it in my head. Are your lights a big help when backing?
  14. Mar 14, 2018 at 6:19 PM
    guyross
    guyross Member
    Guy
    So just use the switch that the lights came with like the one that turns on the stock ones connected to the same relay. Where can I get the appropriate relay? Will it have some sort of a housing? Thanks for your reply.
  15. Mar 14, 2018 at 11:49 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    12 volt constant duty relay as you do plan to leave this on more then a few seconds at a time.
    if your planning to use these lights without the ignition switch on and truck in reverse then your going to have power direct from a constant 12vdc supply
  16. Mar 15, 2018 at 4:14 AM
    guyross
    guyross Member
    Guy
    The provided harness goes directly to the battery with a 15 amp fuse and switch inline. Thanks
  17. Mar 15, 2018 at 5:02 AM
    beez
    Nate
    Yes, I have a camper shell, and my back window is tinted as well. But I think a backup cam is going to help a bit more.
    I will get some pics and a diagram when I get around to finishing the wiring.
  18. Mar 15, 2018 at 5:14 AM
    guyross
    guyross Member
    Guy
    I’m considering a cam too. I was returning my neighbors trailer that required me to back it up his 200’ driveway. I’ve never taken the time to learn to use mirrors when backing trailers. Your pictures and diagram will be awesome. Thanks
