LED dome light mod went wrong
Discussion in 'Technical Chat' started by billyhinson, Nov 10, 2013.
  1. Nov 10, 2013 at 6:43 AM
    billyhinson
    billyhinson [OP] Member
    Billy
    La Grange NC
    13 Prerunner V/6 DC
    Fog Lights
    I installed a led light in my dome. It is the one were you replace the factory bulb with a bulb "like" thing that plugs in to the led light. The problem is when I push the fob to lock the door, instead of the beep beep I would normally hear, there is a constant beep and the doors will not lock. I turned the bulb around, same thing. The unlock part of the fob works fine. The light does too. I have searched and I didn't come up with anything. Thanks
  2. Nov 10, 2013 at 6:48 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    That's the behavior when a door is open.
    Did you shut all your doors?
  3. Nov 10, 2013 at 6:53 AM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Yeah hes right one of your doors is open it has nothing to do with your dome light.
  4. Nov 10, 2013 at 7:35 AM
    billyhinson
    Billy
    La Grange NC
    13 Prerunner V/6 DC
    Fog Lights
    I checked and all are shut. I put the factory light back in and now it wont go off(while it is in the door mode). I don't know what I have done? I didn't mess with anything but the dome light.
  5. Nov 10, 2013 at 7:41 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Dome light will go off in a few minutes if the switch is set to "door"
    Are we feeding a troll?
  6. Nov 10, 2013 at 8:04 AM
    billyhinson
    Billy
    La Grange NC
    13 Prerunner V/6 DC
    Fog Lights
    I closed all of the doors, and checked to make sure it was on door. The light stayed on for 20 minutes. I had to turn it off. Now I am riding and just put ithe light back on door, I opened the passenger door (I am the passenger)and it went off.
  7. Nov 10, 2013 at 8:10 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Dude, your truck is infected, it's going to turn.. Ruuuunn
    :p
  8. Nov 10, 2013 at 8:13 AM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    All these symptoms sound like you're having an issue with a door switch. Your truck thinks a door is open. Is the "door ajar" light on the dash lit?
  9. Nov 12, 2013 at 11:58 AM
    billyhinson
    Billy
    La Grange NC
    13 Prerunner V/6 DC
    Fog Lights
    I double checked everything as far as doors open. Later on I went out for a ride and when I got back. The locks worked. Dont know what happened. Thank yall for the replies.
