LED dome light stays on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACONORM, Jan 11, 2010.
  1. Jan 11, 2010 at 7:50 AM
    TACONORM
    TACONORM [OP] Member
    NORM
    FL
    2010 TRD OR 4X4
    Hello, Does anyone have the same problem as I do with the dome light staying on after changing out to an LED bulb. The LED bulb goes on bright when a door opens, but then stays illuminated only not as bright when the door closes. Don't know why, need help please.
    Thanks
    16 trd or likes this.
  2. Jan 11, 2010 at 7:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    does it go out after about 30 sec or so? if you put the old bulb in does it work right?
  3. Jan 11, 2010 at 8:25 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    Is the switch on? Is the nap light pushed in? Just checking the obvious stuff 1st.
  4. Jan 11, 2010 at 8:51 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Its just some leakage current. LEDs use much less current to light. So a small amount of leakage current can cause the LEDs to light a little. My wife's Altima does this too. there really isn't anything you can do about it without redesigning the entire circuit.
  5. Jan 11, 2010 at 9:04 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Eh, my led dome light works perfectly... I'd mess around with the switch...
  6. Jan 11, 2010 at 11:32 AM
    PreRunnerSeth
    Apex, NC
    Its most likely a reverse current flow. if youre using a LED bulb with a rectifier on it then the reverse current will light the bulb. A bulb without a rectifier will not light with reverse current.
  7. Jan 12, 2010 at 5:35 AM
    TACONORM
    NORM
    FL
    2010 TRD OR 4X4
    I thank all of you for your replies. The dome light thats the problem is the one in the middle of the seats. It does stay on all the time. I noticed the problem one morning when the light was on all night. The front map lights I've replaced with LED's and they work fine. If it is some reverse electricity, I'm not sure what a rectifier is. If that will take care of the problem can it be purchased?
  8. Dec 19, 2012 at 1:27 PM
    OhYeah
    OhYeah Well-Known Member
    so cal
    2006 DCSB
    reviving this thread... have you fixed this OP? has anyone else had this problem?
    like the OP, my dome light stays on. all switch functions work fine except the "door" switch. when a door is open, the light will come on, when all doors are closed, the light will dim, but stay on. thought it would turn off after a while but it doesnt unless i turn the switch to "off"
    I also replaced the map lights but those work fine.
    any idea?
  9. Dec 19, 2012 at 6:44 PM
    OhYeah
    so cal
    2006 DCSB
    Is it the led? I got it from ddm tuning..
  10. Mar 12, 2017 at 8:45 PM
    16 trd or
    16 trd or Active Member
    Daniel
    So cal
    16 trd OR LB super white
    Hid lights
    Having the same issue..did you ever get it figured out
  11. Apr 4, 2017 at 1:18 PM
    2324fire
    2324fire Active Member
    2016 TRD OFF ROAD
    3" lift, 33" nitto trail grappler rubbers, strobe lights, sirens.
    Remedy is a new overhead console. This is due to fusing of the switch. Toyota part number 63650 04070-CO. This is for the TRDOR. Your trim may be a slightly different part number but that is a good starting point i hope. At least this was the issue on mine. Was able to find a console for $125. My dealership wanted $190.35 for the part and $50 to install it. They would not honor another dealerships price. It is a simple install it appears.
  12. Apr 4, 2017 at 2:23 PM
    16 trd or
    Daniel
    So cal
    Hid lights
    Thanks for the info! I will have the dealer check it out at the next service..we'll see what they say
  13. Apr 4, 2017 at 3:46 PM
    2324fire
    2016 TRD OFF ROAD
    Be sure you put regular bulbs back in if warrantee is a possibility.
    16 trd or[QUOTED] likes this.
