led dome lights strobing
Discussion in '1st Gen. Tacomas (1995-2004)' started by michaelsdaddy02, Mar 10, 2015.
  1. Mar 10, 2015 at 2:44 PM
    michaelsdaddy02
    michaelsdaddy02 [OP] Well-Known Member
    New Jersey
    04 Double Cab 4x4 3.8 SR5
    Just put leds in the map and dome lights. When truck is off they strode dimly when i turn them on. If the truck is in acc or on I have no problems. Any ideas?
  2. Mar 10, 2015 at 2:52 PM
    Kchapp
    Kchapp Active Member
    Kevin
    Birmingham
    02 Double Cab SB
    General Grabber At2 on Helo He791 wheels, LED interior dome and map lights , Opt7 Led headlights, Pioneer In dash DVD, Parking brake bypass for DVD, Husky liners, Drop in UTR liner, Stainless D Cab toolbox, K&N air filter, Westin nerf bars, Mounted aux/usb input from head unit. Bluetooth OBDII module.
    2001 and 2002 models need a resistor to compensate for the dimming feature of the dome light. Let me find the link....
  3. Mar 10, 2015 at 2:55 PM
    Kchapp
    Kevin
    Birmingham
    02 Double Cab SB
  4. Dec 31, 2016 at 10:56 AM
    blairrad
    blairrad Yoter
    Missouri
    Other thread, but mine as well only work with the power on, and Flicker/strobe with the power off
  5. Dec 31, 2016 at 10:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Put regular bulbs back in and forget it?
  6. Dec 31, 2016 at 10:58 AM
    blairrad
    blairrad Yoter
    Missouri
    But I want the LEDs!
  7. Dec 31, 2016 at 11:16 AM
    blairrad
    blairrad Yoter
    Missouri
    Is there any way to fix it without soldering a resistor or should I just return them and get new ones?
  8. Dec 31, 2016 at 2:36 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    maybe get rid of the dimmer?
  9. Dec 31, 2016 at 3:12 PM
    Maestro
    Maestro Well-Known Member
    The Master
    I've asked the same question a couple times. Nobody has the solution (except to solder parts into the mix).
    I gave up. The LED lights worked AWESOME in my 2000, but wouldn't play in my 2002. I still haven't found a solution (I am not going to solder a resistor - I want plug and play).
  10. Dec 31, 2016 at 3:23 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    I just tried to put in a LED dome light and it wouldn't even work. OEM light is back in for now
    Which LED lights did you guys use and where did you get it from?
    I used one from SuperbrightLEDs 3110-W10-CB
  11. Mar 20, 2017 at 11:59 AM
    michaelsdaddy02
    New Jersey
    I got a led board light from advanced auto. It's bright I just need to wire a resistor to it.
