LED DRL bulb replacement with stock DRL flasher and NO RESISTORS!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgraham, Sep 11, 2011.
  1. Oct 9, 2011 at 8:57 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i just picked up all putco 360 leds for my arb turn signals the factory front turn signal no drl's and the rear turn signals.
    i also ordered 4 ceramic resistors which i don't really want to use. i was directed to super brightleds.com. they have an led flasher module that supposedly works on newer toyotas i'm going to post a link to it to see what you guy's think.
    like i said i'm going to have 2 leds in the arb and 2 in the headlights and 2 in the tail lights for my turn signals.http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/CF18-08.html
  2. Oct 9, 2011 at 9:16 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    bump this man..... bump this lol i need to order the flasher module so it's here in time for my lights.
  3. Oct 9, 2011 at 4:30 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    bump for some help on this...
  4. Oct 10, 2011 at 9:10 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    where did the flasher module you modded come from inside fuse panel or the one in the engine bay? i'm having trouble finding it altogether.
  5. Oct 10, 2011 at 11:53 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    HI, i got a LED flasher from Super Bright LEDs inc. (314) 972-6200 model number was CF180-08( Led bulb flasher unit) price $12.95. I really cannot vouch for this product as I have yet install. BTW same pin layout but the numbers printed on it are different. Hey wtf for $12.95b worth a shot. BTW also bought all my led bulbs from them. Just been lazy to install.
    Good Luck.
  6. Oct 10, 2011 at 12:14 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    where do you instal the new flasher? i can't even find my factory one unless i'm not recognizing it. i checked the inner fuse panel and the fuse box in the engine bay as well and i don't see anything that looks like the image of the op's flasher.
  7. Oct 10, 2011 at 12:53 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i called superbright leds and they said they don't carry any 12 pin flasher modules. thats what the op is saying you need for our trucks right?
  8. Oct 10, 2011 at 5:44 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i opted to not get the towing package on my regular cab.
  9. Oct 12, 2011 at 6:36 AM
    sledneck
    sledneck Active Member
    Northern Maine
    2011 TRD Sport DC
    MBRP Stainless Duels, AFE CAI Stafe 2, lBilstein 5100's, 886's, smittybuilt Nerf Bars, UWS box, 6000K HID's, Grillcraft grille, Switchback LED signals and DTRL's, 20% tint,
    I grounded down the resistor loop all the way until I broke through checking every little bit and it still didn't fix the hyperflash. When it actually broke through the blinkers would not even work so I had to solder it back together. I guess if you have LED's at all locations front and rear like me you need to splice in actual resistors.
  10. Oct 12, 2011 at 7:26 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i need to find out what flasher ie how many pins the one my reg cab has with no dtrl's and no towing package.
    i'm just trying to run regular led amber turn signals. there seems to be some question about dtrl equipped models of tacoma and non dtrl equiped models it seems they have different styles of flasher modules at least this is what i'm getting from things.
    viet2100 has been using a flasher module to get his blinking correctly.
  11. Oct 12, 2011 at 8:04 AM
    Rellik01
    Craig
    Windermere, Florida
    Props to the OP. Just changed every exterior light with led's minimized the shunt in the flasher and it works like a charm. Front and rear.
    Thanks again
    smokey1.5 likes this.
  12. Oct 12, 2011 at 8:48 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    http://www.tacomaworld.com/forum/lighting/119640-electronic-flasher-09-tacoma-led-install-2.html
    here is the thread viet2100 seems to recommending an 8 pin flasher module? this is what he said he was using i obviously need the 4 led flasher but, this confused me as i was operating under the impression that the tacomas flasher module was a 12 pin unit:confused:
    i called napa auto parts and told them my make and model year and vehicle info told them what i was trying to do and they ordered me a 12 pin led flasher but, it's 50 dollars while others are like 10 to 20 dollars i'm not sure if it will even work but, i guess there is only one way to find out.
  13. Oct 12, 2011 at 8:58 AM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    can you link us to the led's you bought?
  14. Oct 12, 2011 at 11:48 AM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
  15. Oct 12, 2011 at 11:57 AM
    #35
    Rellik01
    Craig
    Windermere, Florida
    Used stock flasher with the OP instruction on grinding down the resister. Worked like a charm. Hardest part was finding the flasher but another poster had good advice turn on you flasher and listen for the clicking. Used superbright led's they have a drop down menu to get everything you need.
  16. Oct 12, 2011 at 1:39 PM
    #36
    sledneck
    Northern Maine
    2011 TRD Sport DC
    Congrats on getting it to work. I have the same truck and wasn't able to. Did you grind down in one place on the loop or even as much as you could? Is there anyway you can take a pic of the end product?
  17. Oct 12, 2011 at 1:40 PM
    #37
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i bought putco 360 leds for all the turn signals 6 bulbs in total my bulbs are not wired like the op's bulbs so modifying the stock resistor is not going to work for me.
    i either need to use the resistors which i really don't want to do or i have to replace the flasher unit completely.
    lol i need halp!
  18. Oct 12, 2011 at 1:48 PM
    #38
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i just got off the phone with napa auto parts and apparently the led flasher module they have for me was originally for a cadillac.
    the guy also said that it was the only 12 pin led flasher he has listed in any book! lol thats not to say someone else might not have one but if the caddy one does not work and if thats all that a national parts chain like napa can get it's not looking good.
  19. Oct 12, 2011 at 6:44 PM
    #39
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    aw man thank you so much i'm going to check this out after ancient aliens lol me and the wife love that show
  20. Oct 12, 2011 at 8:04 PM
    #40
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i believe i see just barley see it when i twist my body under there. how does the module come out though i have tried pulling on it and it seems very resistant to being removed!
    the piece i'm talking about is on the back side of the interior fuse panel and it's light gray in color and what writing i could make out on it say's max 4 bulbs i'm assuming this is the flasher module caribe was talking about i'm just having a problem actually removing it now lol.
    i don't want to muscle it but, if it just pulls out then i'll know i just need more elbow grease but, if i pull to hard i'm worried about breaking something.
