LED DRL bulb replacement with stock DRL flasher and NO RESISTORS!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgraham, Sep 11, 2011.
  1. Jun 7, 2012 at 4:37 PM
    #81
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    I'm interested in switchbacks for my 2012 prerunner with dtrls. I was ready to buy, but didn't like the resister thing using up the equivalent power as if it was still the 4157nak bulbs in dtrl mode. and getting hot and giving the dealer a reason to notice a mod with the truck under warranty....
    But how about putting the load resistors behind the rear light housings; tie into the rear amber turn signal [only] bulbs and the resistor should only have to work during the turn signal mode.... I figure it's the same circuit, right? and resistors wouldn't get hot... (or am I missing something-apologies if someone's already posted this...)
    For that matter, get a couple spare light sockets with pigtails and wire them instead of resistors; let them 'blink' behind the tail light where no one would see them-[po' boy resistors] make the circuit think the front bulbs are still there....
    Oh another idea....what if the rear amber bulbs, 3157a, are switched for the 4157nak bulbs, AND the filaments wired together. The 4157 draws more power and if both low and high filaments are wired together so both flash, wouldn't that maybe add enough wattage to fool the stock flasher unit?
  2. Jun 24, 2012 at 8:46 PM
    #82
    p4l4acv2
    p4l4acv2 Member
    Puerto Rico
    2010 DC 4X4
    Hey JGraham, great mod man. I was wondering when will we see the write-up for this. I imagine you may have more important things to do, but such a fine work will be much appreciated for us normal mortals.
  3. Aug 26, 2012 at 4:49 AM
    #83
    Insightofgwd
    Insightofgwd New Member
    South Carolina
    Silver Streak Mica
    I did the led mod this weekend while replacing my melted factory housing. I ground down the resistor as jgraham told and it works and looks great!7cbb1d93dd1304f6e9d577718025022a_0ad0ea077392a35948735195d403d7c94ee80392.jpg
  4. Aug 26, 2012 at 5:46 AM
    #84
    WARR4NT
    WARR4NT Well-Known Member
  5. Aug 26, 2012 at 6:23 AM
    #85
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
  6. Sep 7, 2012 at 6:55 PM
    #86
    CannondaleMan
    CannondaleMan Active Member
    Live Free or Die! God Bless New Hampshire
    2010 Speedway Blue Double Cab, Long Bed,
    Hey guys. Finally finagled the time to do this mod.
    I used LEDs from www.superbrightleds.com for my '10 DCLB Taco. You do need the CK option for the fronts bulbs. I replaced the DRLs, side markers, and rear directionals. I have LEDs inside the cab and in the third brake light (just have the reverse lights to get next - probably this week.)
    The issue I have run into is that I have finally ground enough away of the resister loop to have the lights not hyperflash, however after about 35 flashes the directional automatically shuts off - I think it just gets too hot and shuts down.
    I too ground through the loop a couple times, thank God for the soldering iron though.
    It took about an hour to get to the point of having it not hyperflash, and I will have to tweak it a bit more so that it does not automatically shut off.
    Incidentally, while replacing the front bulbs in the DRL I noticed that the bulb housings had just started to brown up as though the housing and bulb insert had been getting quite hot. Looks like I got the mod done just about in time so I did not have to replace the entire lamp assembly.
    The LEDs are not quite as bright as the OEM Sylvania bulbs, but I think the lighting looks better in general. I will know how it looks next week when I get back to work and drive home at night.
    Thanks to the original poster as well. Even with the magic of Google there does not seem to be a 12-pin LED flasher out there.
  7. Sep 8, 2012 at 8:17 AM
    #87
    Spruce Juice
    Spruce Juice Well-Known Member
    Sam
    Vancouver, BC
    2012 4 x 4
    Fold A Cover, Factory Class 4 Hitch with Factory Harness, Cruise, Int Wipers, TRD Alloys, Fogs, K&N Air Filter
    You are bang on with the location of the flasher relay on the 012's. I recently added a factory tow hitch electrical harness which came with a blue flasher relay that had to be put in place of the original one which is black. Btw, the factory tow harness only works if the truck has DRL's, at least for a 2.7 base, which tells me that non DRL Tacos may have different flasher relays. I don't know for sure why one cannot use a factory tow harness without DRL's. What I wonder is if extra or excessive heat is generated inside the relay with this mod and if the extra heat makes any difference overall.
  8. Sep 24, 2012 at 7:13 PM
    #88
    seric007
    seric007 Well-Known Member
    this is 100% confirmed working. took off ~25% for 2 rear led turn signals
  9. Oct 5, 2012 at 10:08 PM
    #89
    Sammy1Am
    Sammy1Am Member
    2012 Tacoma
    Thank you for posting this! I was all set to mod my flasher unit (based on some tutorials I'd seen) and then came to find out that because I have a '12 with DTRL, I had a totally different module. Good to know it's still got some grindable / replaceable shunts. I'll try to take pictures when I do mine and post 'em back here.
  10. Dec 8, 2012 at 3:27 PM
    #90
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Calculation example:
    I want to calculate the correct replacement shunt resistor value.
    The current used to provide power to the front & rear signal light flows through the shunt resistor in the flasher's circuit. The current flowing through the resistor provides a voltage level that is measured by the flasher's circuit. The more current flow through the resistor, the larger the voltage measurement.
    The flasher circuit measured voltage needs to be at least 0.049Volts. If it is less than that, the flasher does the hyper-flash output.
    The spec for the LED bulbs I intend to use for the signal lights show 490mA for the front, and 340mA for the back = 830mA. If I want the hyper-flash to let me know when a bulb is not working, then I should calculate a resistor value to provide greater than 49mV at approx. 500mA (0.5Amp) The resistor value should be 0.049V / 0.5A =
    0.098 Ohm. Best match would be 0.1 Ohm (100 milliOhm).
    Next post will look at what power the resistor should be able to handle.
  11. Dec 8, 2012 at 3:28 PM
    #91
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Calculation example: Power rating for the flasher's shunt resistor.
    The one challenge from the example above is that I do use my truck for towing.
    Adding a normal incandescent bulb to the flash circuit = 27W.
    27Watts/12Volt = 2.25Amp . Add that to my LED load from the above post example = 3.08 Amp.
    The 3 Amp load is passing through my new resistor value of 0.1 Ohm. The power, in the form of heat this produces = square of the Amps x Resistance value.
    3A x 3A x 0.1 Ohm = 0.9W The 0.1 Ohm resistor needs to have a power rating of at least 1 Watt. I know from experience, that for long trouble free service life I should double this and use a 2 Watt resistor.
    So now I know I need a (2005-2010 DRL) , 0.1Ohm 2 Watt resistors for my flasher mod.
    You can check out mail order supply houses such as mouser electronics or digikey.
    example:
    http://www.digikey.ca/product-detail...0CT-ND/2021752
  12. Dec 22, 2012 at 5:20 PM
    #92
    bhormberg
    bhormberg New Member
    Hey all. Just did this mod using resistors in place of the factory shunt for a 2009 Taco with LED DRLS and incandescent rear turn signals. A single 0.10 ohm resistor in place of the factory shunt allowed the turn signals to work but not the emergency flashers. I placed two 0.10 ohm resistors in parallel for a resistance of 0.05 ohms and presto, both the turn signals and emergency flashers work.
  13. Dec 22, 2012 at 5:40 PM
    #93
    wacked
    wacked Well-Known Member
    Katy, Tx
    2013 Tacoma Prerunner
    Any pics??
  14. Dec 22, 2012 at 7:50 PM
    #94
    StormTrooperTaco
    StormTrooperTaco Well-Known Member
    Washington
    2013 Taco TRD Sport DCSB
    Plasti Dip Wheels GY Duratracs 20% Tint all around
  15. Dec 22, 2012 at 9:07 PM
    #95
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  16. Dec 23, 2012 at 1:17 AM
    #96
    StormTrooperTaco
    Washington
    Gotcha. Thanks!
  17. Dec 23, 2012 at 1:44 AM
    #97
    DSYLEXC
    DSYLEXC Well-Known Member
    Western Arizona, USA
    SOLD:2012 Tacoma TRD Sport DCLB 4x4
  18. Dec 23, 2012 at 2:46 AM
    #98
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  19. Dec 23, 2012 at 2:53 AM
    #99
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
  20. Dec 23, 2012 at 2:55 AM
    #100
    650H1
    Michael
    VA
    just cuz
