LED fog bulb upgrade max $150?
Discussion in 'Lighting' started by jailbird, Dec 25, 2020.
  1. Dec 25, 2020 at 5:09 PM
    jailbird
    jailbird [OP] Member
    Asheville, NC
    2020 TRD OR MGM
    Any suggestions for LED fog bulb upgrade? Budget tops out at $150 so options are limited. Understand the best route is full replacement w KC but more than I can spend.
    Thanks
  2. Dec 25, 2020 at 5:17 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
  3. Dec 25, 2020 at 5:20 PM
    Tacoma’20
    Tacoma’20 Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
  4. Dec 25, 2020 at 5:30 PM
    ianGP
    ianGP Active Member
    VA Beach
    2020 TRD Pro SW
    2002 Tacoma SR5 *RIP*
  5. Dec 26, 2020 at 11:53 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Best LED fog for under $150 is the OEM LED fogs, they outperform Morimoto and are less expensive. See the review here: Toyota LED fogs. If you can swing a little more, you may be able to find the Diode Dynamics SS3 Sports (covered here: Diode Dynamics SS3) for just a little over your budget on some year end sales (TBD). The SS3s are much higher performing and available in a selective yellow which is more ideal for poor weather conditions.
    Note that replacement LEDs in the factory halogen fogs should be avoided, performance is poor and they cause increased glare for oncoming drivers and reduced performance in the poor weather conditions fogs are intended for. The worst offenders by far are any kind of 'switchback' multi-color bulb, as those products are fundamentally flawed by requiring multiple emitter sets to support multi-color, however for a replacement LED to attempt to work properly the LED must be centered. Because there are two sets required for multi-color, neither emitter set can be centered in the correct location causing far worse performance and more glare. There is a reason why no reputable manufacture makes such products, and only gimmicky companies reselling low quality Chinese products.
    Tacospike likes this.
  6. Dec 26, 2020 at 12:47 PM
    jailbird
    Asheville, NC
    2020 TRD OR MGM
    Thanks Crash, gonna go with the Tungsram Nighthawks. Looking for better performance and after research and your advice it seems LED isn't the best option.
  7. Dec 26, 2020 at 12:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Best replacement bulb choice. Your profile doesn’t say what year/trim truck you have. Note that non-TRD trucks and 2020+ and Canadian trucks all have H16 fogs, which those are not available. You need the high performance H11 fogs that come on 16-19 TRD trucks or 12-15 2nd Gens for the Tungsram Nighthawk Xenons to be compatible.
  8. Dec 26, 2020 at 12:53 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I think every led bulb suggestion should have a bot that automatically quotes you.
  9. Dec 26, 2020 at 1:02 PM
    jailbird
    Asheville, NC
    2020 TRD OR MGM
    It's a G3 TRD OR, so scratch the Nighthawks it seems. Best fog replacement of any typr on the limited $100 or so? Apologies for the back and forth and appreciate the insight.
  10. Dec 26, 2020 at 1:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    For an inexpensive 2020 upgrade I’d look to pickup some OEM 16-19 H11 TRD fog assemblies from the marketplace section. People often sell them for cheap when swapping to an LED assembly. The swap to an H11 fog upgrade alone will be significant, the TRD units have a much wider pattern area than the H16 fogs and are significantly higher in output. From there adding the Tungsram Xenons will enhance performance even further. If you find the right deal on fog takeoffs you should still be able to come close to the $100 mark and sell your OEM units for someone looking to add fogs to their SR5 to help offset a little cost.
    Too Stroked likes this.
  11. Dec 27, 2020 at 8:15 AM
    tclavell
    Troy
    Phoenix, AZ
    G70
    Never mind my nonsense. I didn’t read the OPs post all the way through
