led fog light mod 10,200 lumens clean and simple
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Raxman80, Jun 26, 2014.
  1. Jun 26, 2014 at 9:50 PM
    Raxman80
    Raxman80 [OP] Well-Known Member
    Ray
    Downey ca
    08 4X4 DC SB TRD Off Road
    2.5 king coilovers and 2.5 king adj rr rears. King bumps. total chaos UCA Deaver 3 leaf add. K&N cold air. flowmaster. Chase rack. Leds everywhere General Grabber X3
    led light swap in stock fog light location mod
    hello. i found some led lights that fit in the factory fog light hole on my 08 taco. it does not require a lot of modding. the led lights are 5,100 lumen each.
    here are the the specs
    Available in spot pattern.
    Beam Type: Spot / Flood
    weight: 1 lb
    Amp draw (14V): 4.35
    LED Module: 6x10 CREE
    Lumens (LM): 5,100
    if anyone interested in a set of these hit me up.
    flood or spot available
    65.00 each
    120.00 for a pair
    5.00 each for shipping
    8.00 for a pair if shipped
    here are some in stall pics.
    this is how the light comes
    the factory bottom mount needs to be cut off and ground smooth to fit in the factory fog light hole.
    this is how it mounts up in the factory location. the led light has four 10/32 threaded holes on the back. i used some flat plate to secure it. miner trimming on the inside of the fog light hole. it wont be seen or prevent the factory fog light from being reinstalled. i wired them to the factory fog light switch.
    new led light vs factory fog light.
    light output at 20ft. in spot pattern
    Cmurder likes this.
  2. Jun 27, 2014 at 2:38 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Subd for future purchase
  3. Jun 27, 2014 at 2:46 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
  4. Jun 27, 2014 at 2:50 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Great lights though, bright as fuck. You will get high beamed if you use these as regular fog lights. They make great off-road lights when crawling though.
  5. Jun 27, 2014 at 4:28 PM
    Raxman80
    Ray
    Downey ca
    the lights I'm selling are 5,100 lumens each and 60 watts not 1550 lumen and 27 watts. Big difference...
    Sold out of spot pattern. Flood pattern only.
  6. Jun 28, 2014 at 1:01 PM
    hack4875
    hack4875 1 of 377
    Colorado Springs, CO
    2015 TRD PRO Supercharged
    As for wiring, is there a relay needed? Or you just splice them into the factory fogs?
  7. Jun 28, 2014 at 1:13 PM
    Raxman80
    Ray
    Downey ca
    I just hooked them up to the factory fog light and the 15 amp fuse held
  8. Jun 29, 2014 at 9:35 AM
    Raxman80
    Ray
    Downey ca
  9. Jun 29, 2014 at 8:06 PM
    88JayPizzle
    88JayPizzle Well-Known Member
    Are this ready for installation
    or i gotta do a lil modding
    Interested
  10. Jun 29, 2014 at 8:22 PM
    Raxman80
    Ray
    Downey ca
    A little modding necessary
  11. Jun 30, 2014 at 2:47 PM
    Raxman80
    Ray
    Downey ca
  12. Jun 30, 2014 at 2:51 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    How do these look to oncoming traffic. I used to have an HID kit for my fogs but I uninstalled them cause they blinded opposing traffic and cars I would be behind.
  13. Jun 30, 2014 at 3:34 PM
    Raxman80
    Ray
    Downey ca
    This setup is defiantly for off roading only.
  14. Jun 30, 2014 at 3:45 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay got yah. They looked pretty darn bright in those pictures. They look cool though.
  15. Jun 30, 2014 at 3:58 PM
    Raxman80
    Ray
    Downey ca
    Yes they are. Here in SoCal we don't get too much fog.
  16. Jul 1, 2014 at 11:39 AM
    Raxman80
    Ray
    Downey ca
  17. Jul 1, 2014 at 12:52 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I can't imagine how you're getting more than double the wattage and 4x the lumens when they're the exact same light, just a different brand name. That's the Chinese clones for you... always trying to pad their stats. GLWS
  18. Jul 1, 2014 at 1:01 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    stupid question but aren't fogs designed to not give off so much light that if it is foggy you go blind due to refraction when you turn them on?
  19. Jul 1, 2014 at 1:02 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    This. These lights and ones similar to it are best suited (and legal) for off-road use only.
  20. Jul 1, 2014 at 2:24 PM
    Raxman80
    Ray
    Downey ca
    This set up is for the off roader that wants bright ass lights with not a lot of modding and keeping the factory look. They are CREE 10 watt chips not epistar.
