LED fog lights
Discussion in 'Lighting' started by Firemedic746, Dec 18, 2016.
  1. Jan 17, 2017 at 8:08 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I can't wait.
  2. Jan 18, 2017 at 12:05 AM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    Sub'd For pix of the kc hilites on 2010 taco and @Taylor@KC HiLiTES are they DOT/SAE as well? Can you show some night pix, curious on how bright they are compared to the xb's and also if it has a clean cutoff.
  3. Jan 18, 2017 at 10:45 AM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    Sure thing! They are SAE/ECE street legal. I don't have XBs to compare them against (or know anyone local in AZ with them to meet with) however. But I'll definitely post up any photos you or anyone else would want. I am aiming to have them installed Sunday morning!
  4. Jan 23, 2017 at 8:22 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
  5. Jan 24, 2017 at 12:18 AM
    iRepLONGBEACH
    SoCal
    Did u ever get those fogs installed @KC HiLiTES ? If so, Would love to see the output and cut off line on those bad boys.
    o0oSHADOWo0o likes this.
  6. Jan 30, 2017 at 7:07 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
  7. Jan 30, 2017 at 7:35 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    They're semi installed! I killed my battery that day (running lights without running engine, and a shitty battery over 5 years old). Let me just do a photo dump. I have the cutoff from about 8 ft away, but my Pelfreybilt bumper has a deep recess for the lights so the pattern is wider than it appears. Then there's three photos at different exposures (last one is most similar is named eye). I did my best to block my headlight too in those, and that's prior to aiming the fogs lower. Other photos show how they appear without the lights on. I'll also show it from about a foot away from the wall. I will take more when my new AGM battery comes in!
    tmp_24757-IMG_20170128_1720212100111525.jpg tmp_24757-IMG_20170128_1721082009745750.jpg tmp_24757-IMG_20170128_172111906932963.jpg tmp_24757-IMG_20170128_1721161654729172.jpg tmp_24757-IMG_20170128_1648241589154561.jpg tmp_24757-IMG_20170128_164827168671901.jpg tmp_24757-IMG_20170128_165101513199507.jpg tmp_24757-IMG_20170128_1719501978659099.jpg
  8. Jan 30, 2017 at 7:46 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Here's two videos. They may help show color for those curious @o0oSHADOWo0o My apologies for the camera orientation. Like I said, I can retake any photos and videos!
  9. Jan 30, 2017 at 8:45 PM
    snowbrdd
    snowbrdd Well-Known Member
    Looks very nice.
    Taylor@KC HiLiTES likes this.
  10. Jan 30, 2017 at 8:50 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    So the website originally stated that the lenses were amber but they are actually clear. Thank you for clarifying that. Can you please confirm that the lenses are actually glass as the site states and not plastic?
  11. Jan 31, 2017 at 7:50 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Yes, they are!
    o0oSHADOWo0o[QUOTED] likes this.
  12. Feb 13, 2017 at 7:04 PM
    Geeterman
    Geeterman Dave - THL
    Dave
    2017 Tacoma TRD Off-Road 4x4
    2017 TRD OR 4x4 King Shocks OME Heavy Springs Prinsu Cab and Cap Racks Fuel - ANZA D583 Bronze 17x8.5 -6mm General - Grabber X3 LT265/70R17/10 121/118Q Baja Designs S8 30" Driving/Combo LED Light Bar Baja Designs S2 Pro , Work/Scene LED Southern Style Offroad - Slimline Hybrid w/30" Baja Cutout All-Pro Off-road APEX Sliders Leer 100R Top - WeatherTech Lasercut floormat’s RotoPax - LOX Pack, 2 Gallon Water, 2 Gallon Gasoline GEN2 x2 PowerTrays - Bussmann RTMR REDARC - Dual Input 25A In-vehicle DC Battery Charger
    Thanks. Do you also sell the light bar as well?
  13. Feb 14, 2017 at 6:57 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Which light bar are ya referring to?
  14. Feb 16, 2017 at 10:20 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
  15. Feb 16, 2017 at 10:28 AM
    #35
    Geeterman
    Dave
    @Taylor@KC HiLiTES miss-quoted.
  16. Sep 8, 2017 at 12:15 PM
    #36
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
    @Taylor@KC HiLiTES Do you guys have a wire harness for the amber fogs for guys who have an 4cyl SR5 that doesn't come stock with fog lights or a harness? Something to run off an individual switch?
  17. Sep 8, 2017 at 1:48 PM
    #37
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The KC Universal Gravity fog light set comes with a harness and generic switch. I'm not a big fan of the harness because it doesn't use a relay. Granted the light set pulls very little power (less than 2 amps), but I'd rather run a relay and only have to run a few hundred milliamps through the switch/relay coil than run all the power through the switch. I have a WinJet fog light setup that I installed late last year. The universal fog light set will be replacing them when I install my Demello bumper tomorrow. I'll be cutting the connectors off the KC harness and soldering them into the harness I'm currently running.
    amRRussel[QUOTED] likes this.
  18. Sep 9, 2017 at 7:49 AM
    #38
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Yep, as @buyobuyo mentioned, our universal set will come with everything you need to get the lights going. These lights draw in 0.74 amps and we use a 30amp switch with this kit. Typically these lights are used in aftermarket bumpers as they have a bottom mount design rather than any vehicle specific mount.
