LED Fog Lights
Discussion in 'Lighting' started by Jessel, Feb 15, 2020.
  1. Feb 15, 2020 at 3:23 AM
    Jessel
    Jessel [OP] Well-Known Member
    Jesse
    Manitoba, Canada
    13’ Super White TRD Sport
    On a budget is it worth it to put led bulbs in stock housing. Or just plain stupid. If so what do you recommend for aftermarket fogs?
    Tullie D likes this.
  2. Feb 15, 2020 at 3:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Don’t put LEDs in the factory fogs, you’ll end up with a bunch of glare. Replace them with LED assemblies, you can then also sell your stock ones. Look at this thread with all the comparisons, best budget option is Toyota’s OEM LED fogs, they are about $125 set, better would be Diode Dynamics SS3 sport at $200, best is the SS3 Pro model at $320. The SS3s are also available in yellow which is better for fog conditions. Links to the lights mentioned at the top of the thread.
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    lynyrd3 and Jessel[OP] like this.
  3. Feb 15, 2020 at 3:27 PM
    Jessel
    Jesse
    Manitoba, Canada
    Awesome thank you
    crashnburn80[QUOTED] likes this.
  4. Mar 31, 2020 at 6:17 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I think you're going to find that a spot / flood combination light is actually a very poor pattern for street use. But, for $25 they're probably not going to have enough power to bother oncoming drivers either.
  5. Apr 1, 2020 at 12:20 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    There is quite a bit more to LED fogs than that. What you have made is illegal LED lights with a non-compliant pattern providing blinding glare to oncoming drivers due to a lack of engineered beam pattern cut off, which will also be ineffective in fog. Just don't run them on the street with other vehicles ahead of you.
  6. Apr 1, 2020 at 12:43 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Jessel[QUOTED][OP] likes this.
