LED footwell mod problem
Discussion in 'Lighting' started by t.robert, Apr 14, 2010.
  1. Apr 14, 2010 at 8:45 PM
    t.robert
    t.robert [OP] Well-Known Member
    Taylor
    Scottsdale, Az
    07 Access Cab 4x4 Off-Road Package
    TSB in rear, 5100 in front, Limo tint all the way around, 50% tint on windshield, Grillcraft grille, 4 Hella 500 lights mounted behind grille, XDI intake, URD short shifter
    I just did the mod where i put an orange LED on under each footwell. I tapped into the climate controls so I would be able to dim them. The problem I ran into is that I wired the the passenger LED straight off the climate control then I wired the driver LED off of that one. My driver side LED is not nearly as bright as the passenger side. Can someone please tell me how to fix this.
  2. Apr 15, 2010 at 1:56 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    here is how I ran my wires. one power wire and they all connect at the same spot so none of them get power before the other
  3. Apr 15, 2010 at 2:00 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    ^^^^ That's the ticket! ^^^^^:D
  4. Apr 15, 2010 at 2:15 PM
    t.robert
    Taylor
    Scottsdale, Az
    How did you connect them at the same spot? I suspect you made some sort of plug?
  5. Apr 15, 2010 at 2:17 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I just used a crimp wire connector, put the power from the truck on one side and then twisted all the LED powers together and stuck them in the other end and crimped.
  6. Apr 15, 2010 at 2:24 PM
    t.robert
    Taylor
    Scottsdale, Az
    Okay cool,
    do you need a ground on the switch too?
  7. Apr 16, 2010 at 6:29 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If I undersand Keason's diagram correctly--No. The LED's are grounded on the right side of the diagram (black color). The switch appears to control the +12V signal (red color). When the switch is closed the circuit is complete and current will flow from the left (add-a-fuse), through the switch and to the LED's which are grounded to some place in the truck.
    I hope that helps you.
    Keason, I like your diagram man :)
  8. Apr 16, 2010 at 7:17 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    you are very right sir. I have been asked this a few times so I made up a diagram a while back. It's easier to explain if you can actually see it, well for me it is, I'm a visual learner.;)
  9. Apr 23, 2010 at 7:55 PM
    lb86
    lb86 rookie
    Pensacola
    White 06 Prerunner Reg Cab
    i just ordered two of the weather proof strips of LEDs from Oznium, i hooked them up acording to your diagram bu t can't seem to get them to work. i understand the concept but this is my first time tampering with the add a fuse. also, do i need to ground the switch and the LEDs?
  10. Apr 24, 2010 at 7:57 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    If you don't have a ground you don't have a circuit. That would be the place to start.
    Also LEDs must be wired in the right direction if they are backwards nothing will happen.
  11. Apr 25, 2010 at 11:24 AM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    you could also ground it to the door switch so the leds turn on when the door is opened.
  12. Apr 25, 2010 at 8:50 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    that might be getting a little complicated for his first run. the switch doesnt have to be grounded, but your LED's do. Also as said above, make sure they are the correct direction, one side will be + and other will be -
  13. Apr 25, 2010 at 10:28 PM
    t.robert
    Taylor
    Scottsdale, Az
    Thanks for the help guys, I just finished all my lighting mods this weekend.
    Orange LED's in footwells and in center counsel vent in the back.
    Cool white led's in the dome and map lights.
    55watt 6000k Hi/lo beam HID's
    35watt 600ok HID's for the fogs.
    Loving the new lights and getting flashed a ton
  14. Apr 26, 2010 at 5:55 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
