LED Front Turn Signal conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skoock, Aug 24, 2019.
  1. Aug 24, 2019 at 2:06 PM
    Skoock
    Skoock [OP] Member
    Z
    '10 TRD Sport DCLB
    I recently swapped out my original headlights for another set of OEM headlights. I used same turn signal bulbs and I swear that they are starting to discolor my new headlights already.
    I did some digging into this and realized fogged headlights plague our trucks and some people speculate that the turn signal bulbs heats the housing. Anyone else have any information on this? Moreover anyone swap LEDs into turn signals without the computer telling you a lights out?
  2. Aug 24, 2019 at 2:28 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you mean fog as in the the plastic on the outside is getting faded, that has nothing to do with the any of the bulbs.
  3. Aug 24, 2019 at 2:30 PM
    gotoman1969
    You can swap to leds but will have to add a resistor so you don’t get the hyper blinker.
  4. Aug 24, 2019 at 2:30 PM
    Skoock
    Skoock [OP] Member
    Z
    '10 TRD Sport DCLB
    On the inside of the headlight there's a seperate lens for the turn signal. Mine is starting to look discolored like my old headlights.
  5. Aug 24, 2019 at 2:31 PM
    Skoock
    Skoock [OP] Member
    Z
    '10 TRD Sport DCLB
    Any idea where to solder the resistor in or how many ohm? I have a basic understanding of electrical but I'm quite terrible at it lol
  6. Aug 24, 2019 at 2:35 PM
    gotoman1969
    Unfortunately no. I didn’t do the blinkers for just that reason. Didn’t feel like adding a resistor plus the resistors get very hot and need to be placed very carefully. When I did look into it, at the local auto parts store they actually carried the resistors right next to the bulbs.
  7. Aug 24, 2019 at 9:26 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    There’s a relay that you can swap out on the fuse block under the dash that will fix the hyper blinker, can be had on eBay.
  8. Aug 24, 2019 at 10:56 PM
    Muddinfun
    Muddinfun Well-Known Member
    Nobody makes a flasher for Tacos with DRL. Since the OP mentions melting turn signals, that's a clue that he has DRL. I did away with my DRL, installed LED turnsignals and a Smart tap flasher, and I'm happy with how it works.
  9. Aug 25, 2019 at 8:06 AM
    Skoock
    Skoock [OP] Member
    Z
    '10 TRD Sport DCLB
    Any links for the parts you used? Yes you are right my turn signals are wired to my DRL and I would be happy to change that to your set up
  10. Aug 25, 2019 at 1:54 PM
    Muddinfun
    This thread has the part number for the grey plastic jumper block.
    https://www.tacomaworld.com/threads/disable-dtrls.600706/#post-20188878
    Here's the Smart tap flasher.
    https://www.diodedynamics.com/smarttap-cf18-led-flasher-module.html
    Here is a thread that goes into very good detail on how to install DRL. That's not what you want to do, but the disassembly instructions are there.
    https://www.tacomaworld.com/threads/05-drl-daytime-running-lights-install-oem.1475/
    The front LED turn signals MUST be CK. If the description doesn't say CK, they're not CK. The rear turnsignal sockets only have 2 contacts so they don't matter if they're CK or not.
    I bought most of my LEDs from jdmastar on ebay.
    For a LED flasher in other vehicles not supported by Diode Dynamics, this is the place to go. I have 1 of their flashers in my RX8 and it does the same functions as the Smart tap flasher, plus it also does arrival lighting. (The Smart tap flasher lists arrival lighting as an option, but it doesn't work on Tacoma's. The departure lighting does work very well with the Smart tap flasher.)
    http://www.autowindow.com/
  11. Aug 25, 2019 at 4:08 PM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
  12. Aug 25, 2019 at 4:54 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I also did the Smart Tap flasher and LEDs, love it, especially the several blinks by tapping the stalk for lane changes. FYI, you'll also need a jumper block for the non-DRL trucks, it's under $10 from the dealer, but they'll probably have to order it. Your flasher is plugged into a harness that at the other end plugs into the socket for the normal flasher, as well as the socket you'll plug the jumper into.
    A lot of writeups say you have to disassemble the dash to get at all this stuff that's on the backside of the fuse block. After you're done with all that you'll definitely have better access, but IMO it's easier to suck it up and do it in place... it can be done. I did it blindly, laying upside down under the dash, but none of the plugs have retainer clips or anything, just have to feel along the harness and wiggle the plugs out.
    I personally advise against resistors unless there's just no other plausible solution... they just take the higher current draw, heat, and ability to burn out from the bulbs, and move it somewhere else, eliminating most of the benefits of LEDs.
    Skoock[OP] likes this.
  13. Aug 26, 2019 at 9:42 AM
    Skoock
    Skoock [OP] Member
    Z
    '10 TRD Sport DCLB
    Thanks everyone for the help! I'm new to these forums and am happy to see how helpful everyone is. Cheers :cheers:
    REDdawn6 and Muddinfun like this.
  14. Aug 26, 2019 at 10:15 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Got a link on how to do it? I just installed new headlight housings and don't want to melt the lenses again.
  15. Aug 26, 2019 at 10:37 AM
    Muddinfun
    All the links are in my post above.
  16. Sep 30, 2019 at 12:22 PM
    MarkMO
    MarkMO What you get with a Brain Aneurysm Rupture
    Mark
    St. Louis, MO area
    '11 ACLB SR5 4x4 Gray Mica
    Discoverer AT3 4S Leer 700 Series Topper
    Hey fb40dash5, I have questions for you. I'm not sure I'm following some things you said.
    "FYI, you'll also need a jumper block for the non-DRL trucks, it's under $10 from the dealer, but they'll probably have to order it. Your flasher is plugged into a harness that at the other end plugs into the socket for the normal flasher, as well as the socket you'll plug the jumper into."
    I removed my fuse box so I know my flasher is plugs into the back of my fuse box. Is yours the same? My truck is also non-DRL, but i don't know what you are referring to here, could you please explain. Am I missing something here?
  17. Sep 30, 2019 at 12:32 PM
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    Thanks for the great info. On the website for the Smart Tap Flasher, it states a number of functions can be activated (i.e. Tap-to-Signal, Unique Hazard Functions and Arrival and Departure Modes) but that they are only compatible with certain vehicles.
    Were you able to activate these or use any of these additional features? Sounds interesting for on $60.
  18. Sep 30, 2019 at 12:32 PM
    Muddinfun
    Since your truck does not have DRL, all you need to do is pluck out the flasher and pop in the Smart Tap flasher.
    outxider likes this.
  19. Sep 30, 2019 at 12:36 PM
    Muddinfun
    The only function that doesn't work on Tacos is the arrival lighting. My favorite features are departure lighting and alternating hazard flashers. People really do slow down more for alternating lights.
    DLillest[QUOTED] likes this.
  20. Oct 1, 2019 at 3:52 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    6 ohm resistors
