LED H11 Lamps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoAdventures, Jun 13, 2024.
  1. Jun 13, 2024 at 12:08 PM
    TacoAdventures
    TacoAdventures [OP] Active Member
    Hi everyone,
    Me again!
    My low and high beam lights on the passenger side went out. I am taking the opportunity to swap out the halogens and pop in some LEDs!
    I went to the Canadian Tire and they sold me the Ignite H11.
    They brought me back 2 boxes with a pair of lights in each.
    I asked if there were separate bulbs for low and high and they told me the same bulb can be used for both high and low beams.
    IS THIS TRUE?
    I can't seem to find any statement anywhere that confirms this :(
    As always,
    Thank you for your time.
  2. Jun 13, 2024 at 12:28 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Stevie17 and Barsoom like this.
  3. Jun 13, 2024 at 12:38 PM
    TacoAdventures
    I have not put them in yet. I have looked through that thread and I didn't see anything that said the same bulb can be used in both the high beam slot and low beam slot.
    That doesn't feel right though.
  4. Jun 13, 2024 at 12:43 PM
    RichochetRabbit
    LED throws light in 3 directions, mostly. Maybe some to the other sides of the "rectangle". Halogen bulbs throw light in all directions and halogen assemblies are designed to reflect from ALL directions. The driver sees some greater light but no guarantee it throws more light farther. But oncoming drivers see odd patterns and ultra-bright slivers too often.
    Philips H9, or I use NAPA BP1265/H9-N (remove the green insert, easy).
    BillF1564 and Barsoom like this.
  5. Jun 13, 2024 at 12:51 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yes using led it’s the same bulb.
    I have Auxito and love them in my projector housing.
    A bunch of guys at work also use the Auxito leds and love them.
    I’ve ran them in a previous truck and they last along time.
    LEDs need to be timed seems the better ones come set up.
    The Auxito lights were.
    TacoAdventures[OP] likes this.
  6. Jun 13, 2024 at 1:47 PM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    LEDs will light up the foreground, but not further back. Your brain thinks it see more, and you do, right in front of the car, but not ahead on the road, where it counts.
    This is a guy who designs automotive lights for living:
    3rd Gen HID vs LED vs Halogen H11 projector headlights
    Read it before putting LED bulbs into a housing designed for halogen bulbs.
  7. Jun 13, 2024 at 1:49 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    lots of this!
    BillF1564 and Stevie17 like this.
  8. Jun 13, 2024 at 1:49 PM
    Barsoom
    NW GA OTP
    You can't time "time" plug in LED bulbs. Diodes are in the wrong place for a halogen or projector housing and its optical center (LED substrate+LEDs are much thicker than halogen spiral) and emit light in the wrong direction (LEDs are directional, halogen are omni-directional). Always have, always will be.
  9. Jun 13, 2024 at 1:56 PM
    RichochetRabbit
    At least 1 per week ... "Someone tolded me that they be muchly brighterly and perfectly!"
  10. Jun 13, 2024 at 1:58 PM
    TacoAdventures
    Thanks, everyone!
    Stevie17 likes this.
  11. Jun 13, 2024 at 1:58 PM
    Barsoom
    NW GA OTP
    I blame it on the 4cyl fart can exhaust Honda JDM modding bros. Same mentality.
    BillF1564 likes this.
  12. Jun 13, 2024 at 2:38 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    It’s a mess on the Facebook groups. At least once a day somebody asks about bulbs and you have all the people claiming my Amazon led bulbs are awesome! So much brighter! My friends love them too! Meanwhile it’s the shittiest LED bulb ever produced that even china sold them at a discount
    Barsoom[QUOTED] likes this.
  13. Jun 13, 2024 at 2:46 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    There’s only one LED bulb that’s even remotely worth it and it’s the Auxito with the .079” board (they make different types, the ones I just mentioned are the best). Virtually no shadows and they work well in a projector housing.
    I’ve tried others, Sylvania, Morimoto, GT, they all suck.
  14. Jun 13, 2024 at 4:12 PM
    Barsoom
    NW GA OTP
    1. It is still a bi-directional light source, vs omni-directional. Projector hosing gets less than 1/2 of light.
    2 .079" board thickness is 2mm. Halogen spiral is 1.42 mm. Add in the thickness of diodes themselves, and you are looking at 3.5mm or so vs. 1.42mm. LED thickness is 2.5x thicker than halogen light, ie it still would not be in the optical center of the lense.
  15. Jun 13, 2024 at 4:19 PM
    Rusty66
    Rhode Island
    .079 is the thickness of the board and SMD combined and I know they are bi directional Sherlock.
    I never said they were great, I said they’re better than most I have tested.
  16. Jun 13, 2024 at 4:26 PM
    Barsoom
    NW GA OTP
    Then say what you mean, Holms, do not ASSume that others can read your mind. Board means board, not assembly.
  17. Jun 13, 2024 at 4:28 PM
    Rusty66
    Rhode Island
    I did, you were the one who ASSumed.
  18. Jun 13, 2024 at 4:34 PM
    RichochetRabbit
    Have you driven INTO those bi-directional/not-focused LEDs in SUV, Civic, Corolla, etc? That is the problem. Also the length of the light projected down the road is more relevant than the backwash/glare it seems looking through the windshield.
    crashnburn80 did measure "downstream" and "glare" and "even/uneven illumination".
    BillF1564 and Rusty66[QUOTED] like this.
  19. Jun 13, 2024 at 4:49 PM
    Rusty66
    Rhode Island
    Yes, I’ve read all his stuff. Very informative.
    I think the whiter light gives people the illusion that they can see better…..but they are very distracting to oncoming traffic.
