LED headlight brightness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 508Tacoma, Dec 31, 2018.
  1. Dec 31, 2018 at 2:15 PM
    508Tacoma
    508Tacoma [OP] Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    I just installed some NAO H11 headlights recently and it seems one bulb is brighter than the other. Anyone ever experience anything like this? Is there anything I can do to fix this? Would it be possible I need to clean the housing?
    NAO H11 (H8/H9) Led Headlight Bulb,56w 7600Lm Ultra Bright Led Headlights,6500k White All in One Headlamp LED Conversion Replace HID & Halogen https://www.amazon.com/dp/B078NLFFSX/ref=cm_sw_r_cp_api_i_atPkCbHJ5PW35
  2. Dec 31, 2018 at 2:19 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    I don’t know the answer to your question, but I notice your sig says you live in MA. From what I understand LED’s aren’t the greatest for driving in snow etc because they put out such little heat compared to a halogen. I’m sure you researched this though, but just mentioning it because I’m sure you guys have snow and stuff where you are located and it may be a pain if you are driving when it’s snowing hard. Let us know if you get the brightness figured out though. Happy New Years!
    508Tacoma[OP] likes this.
  3. Dec 31, 2018 at 2:22 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Switch the bulbs and see if the brightness carries with it. That should point to where your issue is.
  4. Dec 31, 2018 at 2:37 PM
    508Tacoma
    MA
    Appreciate the response! Happy new year!
  5. Dec 31, 2018 at 2:38 PM
    508Tacoma
    MA
    Thanks Rob! Love the YouTube videos!
    Rob Daman[QUOTED] likes this.
  6. Dec 31, 2018 at 2:46 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    thanks for watching. let us know what happens.
  7. Dec 31, 2018 at 4:45 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    Do you have both bulbs turned the same way? The set of leds need to face the 3 and 9 o'clock position.
  8. Dec 31, 2018 at 4:49 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Make sure you installed both new bulbs in the low beams. It looks like your bulbs can be installed in both the high (H9) and low (H11) beam positions.
  9. Dec 31, 2018 at 5:37 PM
    508Tacoma
    MA
    This could be it! I have a feeling right now they are faced the same way. I will rotate and update if that did the trick. Thanks for the help.
  10. Dec 31, 2018 at 6:51 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Not to mention the LED isn't designed for use in our projectors...light is going to bounce around everywhere.
  11. Dec 31, 2018 at 7:07 PM
    508Tacoma
    MA
    So would I need to get a whole new headlight setup in order to run LEDs. New to the lighting game
  12. Dec 31, 2018 at 7:10 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    No, the cutoff with LEDs is fine in our projectors. Yes, they're not designed specifically for LEDs, but its not blinding if you have them adjusted properly.
    abhamber likes this.
  13. Dec 31, 2018 at 7:27 PM
    mrCanoehead
    Ottawa
    Honestly the best thing is just to cut the tab out of H9 bulbs for use as low beams. It takes 30 seconds to do with a dremel. The filament is in the same place so the optical geometry will still be correct.
    The stock H11 bulb gives you 1100-1400 lumens. The H9 gives 1760-2240.
    The H11 bulb is designed for long life at the expense of flux. The H9 is designed for maximum flux at the expense of long life. Most LED bulbs do not produce as much light as an H9 bulb. The H9 bulb will be 20% of the price of the LED bulb.
    crashnburn80 likes this.
  14. Dec 31, 2018 at 7:38 PM
    TRD493
    Dave
    Texas (DFW)
    Cutoff may still be there but the light will not project a hot spot like it should so you lose distance. It looks brighter because of all the light in closer to your vehicle.
    mrCanoehead likes this.
  15. Dec 31, 2018 at 7:40 PM
    TRD493
    Dave
    Texas (DFW)
    Yes, to run them properly.
    508Tacoma[QUOTED][OP] likes this.
  16. Jan 1, 2019 at 4:14 AM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
  17. Jan 1, 2019 at 9:59 AM
    508Tacoma
    MA
  18. Jan 1, 2019 at 11:08 AM
    mrCanoehead
    Ottawa
    "Whiter" is not the same thing as "can see better."
    Your projector headlight is designed for an H11 bulb which produces light radially around a small-radius filament. The whole thing is designed in CAD with ray tracing software, it is engineered as a total system.
    An LED is a rectangular chip, the geometry is not the same. It sort of works, but there are hot spots and the throw is not as good as TRD493 said.
    There is a lot of BS in the advertised specifications of LED bulbs. They take the claimed output in lumens from the chip manufacturer, and multiply it by the number of chips in the assembly. It is true that the bulb will produce that. For about 1 second until the chip heats up. And they don't take into account optical losses in the path out the front of the headlight lens. The true output is way less than what is claimed, and it depends very strongly on where you measure it because there are hotspots due to the geometry issues.
    If you are in Massachusetts right now, you probably drive through snow and ice precipitation sometimes. An H11 or H9 bulb will melt that off. An LED bulb, not so much.
    In terms of actual optical performance, by which I mean getting the best chance at seeing stuff as far ahead as you can, you are much better off by modifying an H9 bulb. Most of them will give you north of 2000 lumens in the real world, and that is about the best you can do without going crazy on retrofitting totally new headlights.
  19. Jan 1, 2019 at 11:22 AM
    508Tacoma
    MA
    Thank you for your response. I really appreciate all of the feedback. I am learning more each day. Looks like I am going to put back in my stock bulbs for now until I can figure out the look I am going for.
  20. Jan 1, 2019 at 11:28 AM
    TRD493
    Dave
    Texas (DFW)
