LED headlight bulb suggestions
Discussion in 'Lighting' started by DLRIII, Apr 12, 2018.
  1. Apr 14, 2018 at 8:17 AM
    JRH_Tacoma
    JRH_Tacoma Well-Known Member
    Charlotte, NC
    2017 BBP Tacoma TRD Sport 4x4
    No harness needed, just plug in the new bulbs and you’re good to go.
    ocscott[QUOTED] likes this.
  2. Apr 17, 2018 at 11:18 AM
    Prinxace
    Prinxace Well-Known Member
    New England
    2017 Super White TRD OR DC 4x4
    Do I need different bulbs for the fogs and high beams? or do I just run the H11's through out.
  3. Apr 17, 2018 at 12:34 PM
    JRH_Tacoma
    Charlotte, NC
    The Hikari Philips LED bulbs should be fine for the high beams too. I kept my high beams stock halogen since I really don't use them much. Not sure about using Hikaris as fog lights. I have the Morimoto XB LED fogs and can personally recommend them. Easy install and they match the LED DRLs and Hikari LED low beams very well. Plus they look tinted when they're off for additional cool factor.
    mobgma and ResidentCarbon like this.
  4. Dec 20, 2018 at 9:39 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    LED are also susceptible to moisture, vibration and lifespan because of overheat and if that happens you can't just replace the bulb or ballast, you have to replace the whole thing which isn't cheap.
  5. Dec 20, 2018 at 10:55 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Good LEDs also are marginally less expensive to HID and sometimes even more expensive than HID. Lotta variables
