LED Headlight Bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, Jun 6, 2013.
  1. Jun 6, 2013 at 1:20 PM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    I have a quick question. I have done some searching so far and not much luck. I have a 05 Tacoma. The headlights are stock. Is there a bulb where I can just replace the bulbs with LED bulbs? Ive heard of this with lighting in RV's, trailers, etc but havent heard of it in actual headlights. Does anyone have experience with this? Pictures? Recommendations?
    Thanks,
    Alan
  2. Jun 6, 2013 at 1:23 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    You need several very high power leds with some serious heat-sinking to make viable LED headlights. There is no such thing as a drop in LED bulb replacement for headlights that will generate enough light.
  3. Jun 6, 2013 at 1:26 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Why not go HID??
  4. Jun 6, 2013 at 1:26 PM
    prerunner32
    Alan
    Foothill Ranch
    I was thinking the same thing. I haven't done to much research on the subject lately and you know how technology is. I was thinking there could have been a possibility that something new has been introduced.
  5. Jun 6, 2013 at 2:18 PM
    Madcat207
    Madcat207 Well-Known Member
    FL
    08 Double Cab Long Bed Sport
    Quite honestly, a good setup would cost no more than $50 a light..
    Cree has a new module out , the MtG-2.
    http://www.cree.com/led-components-... Modules/XLamp/Data and Binning/XLampMTG2.pdf
    This module, at 6V , 3A, will do 2000 linens (more than most common headlights). There are already several handheld flashlights that are being built ln this.. the heatsinking is nothing impossible.
    So, you can buy a led on a 20mm star for $18. Get a buck driver (and board) for 10-15. Mill a custom pill/ heatsink for 15 each... there is you light. It really should NOT be complicated to get a high lumen led in your headlights....
  6. Jun 6, 2013 at 5:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    60 watt H4 bulb 1650 lumens. LED build it your self maybe be an issue as they need to be in the focal point @ 180* pretty hard to do. You want lots of light fairly cheap rallylights.com go with a 100/80 watt H4's they will make the stock lights look yellow.
  7. Jun 6, 2013 at 5:44 PM
    aj hank
    aj hank Well-Known Member
    AJ
    412 PA
    09 Regular cab
    Hi/lo HIDs, window tint, keyless entry
    Www.ddmtuning.com has the hi/lo kit (if yours only has 1 bulb) for like $55 I think. Lifetime warranty on the ballasts. I've had 2 sets for different vehicles and have a bunch if friends who have had the same ones. No problems and a lot better than spending $200+ on HIDs. Shipping usually takes about 3 weeks since they come from Japan but worth the wait.
  8. Jun 7, 2013 at 4:23 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Thanks for the heads up they have good prices need some for my camper.
  9. Jun 7, 2013 at 6:49 AM
    ManMan
    ManMan Well-Known Member
    But it IS complicated... And that's why they don't exist yet. You can't just throw a bulb in and call it a headlight. A LOT of development goes into the reflector/lens to get a beam pattern that is suitable for driving, especially while not blinding oncoming traffic.
    That is exactly why HID conversions are generally a bad idea as well. The focal point from the element to the reflector changes and you end up with a lot more scatter which means blinding oncoming traffic AND less useable light on the road
