Led headlight bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyFXR88, Nov 11, 2015.
  1. Nov 13, 2015 at 9:04 PM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Eric,
    Not understanding the question.... as in the HID's coming loose? If so, I would have to check. They were installed on Monday.
  2. Nov 13, 2015 at 9:05 PM
    ericsan777
    ericsan777 Well-Known Member
    Eric
    Annette Island, Alaska
    2016 Tacoma MGM DCSB 4X4 TRD Sport Delivered to me 11/20/15
    There has been some complaints that the Morimoto bulbs moving when hitting bumps on rough terrain. Just curious if you've noticed this as well.
  3. Nov 13, 2015 at 9:11 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    May not notice it as much in the projectors but I did notice that the bulb itself has some give in the base. If it was rigid I think it would probably destroy the light after a couple of bumps.
  4. Nov 13, 2015 at 10:32 PM
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    Hi Sam B,
    With your Morimoto HIDs did you install the relay that attaches directly to the battery and then attaches to the bulbs harnesses or did you go straight plug n'play?
    If you did install the relay, where did you mount it in the engine compartment?
    Trying to find a spot where I don't have to drill for the mounting screw!
  5. Nov 14, 2015 at 5:12 AM
    Sam B
    Samuel
    Poway, Ca.
    none
    Just to the left of the battery I removed the screw from the radiator shroud. Had to drill the relay bracket hole slightly larger to get the screw to fit. The relay hangs straight down.
  6. Nov 14, 2015 at 6:19 AM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Sam you have the item numbers for the ones you used?
  7. Nov 14, 2015 at 1:13 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    for which lights???? or all of them?
  8. Nov 14, 2015 at 1:17 PM
    gsxxr
    All of them if you dont mind. I'm going to order the same ones you got.
  9. Nov 14, 2015 at 1:26 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    From Sam B's earlier post - these are the high beams:
    The VLED LMZ Platinums
    http://www.vleds.com/bulb-type/headlights/h11-h8-h9/h11-ultra-lmz.html
    I am ordering a set today. I assume the collar color (black or silver) is simply personal preference and for 99% of the people there is no preference for one vs the other.
    :cheers:
  10. Nov 14, 2015 at 2:27 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    Chief_Wildcat likes this.
  11. Nov 14, 2015 at 2:29 PM
    gsxxr
  12. Nov 14, 2015 at 2:30 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    Hank...correct. And the recommended installation is to run the light all the way out from the collar then adjust so the lights are horizontal(side to side). There is a line on the light end and it should be vertical. takes a couple of trys but not hard to adjust.
  13. Nov 14, 2015 at 2:34 PM
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Sam,
    Really cool of you to post that info - many thanks!
    For the fogs, does VLEDS not offer any direct replacement LED bulbs for the 2016 Taco?
  14. Nov 14, 2015 at 2:44 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    The fogs are H11's. I don't know of a specific replacement. It is a matter of choice. That's why I went with the Xenon Depot. They don't need the VLED LMZ's.
  15. Nov 14, 2015 at 2:53 PM
    #35
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Great - thanks... I'm new to all of this LED/HID lighting so I do appreciate the info and wealth of experience!
    :thumbsup:
    Sam B likes this.
  16. Nov 14, 2015 at 2:55 PM
    #36
    8102
    British Columbia
    I went with the VLED LMZ's for my Fogs, 3000 LM.
  17. Nov 14, 2015 at 2:57 PM
    #37
    8102
    British Columbia
    Thanks Sam B,
    I appreciate you taking the time to answer, you are truly blazing the trail for the rest of us. :bowdown:
  18. Nov 14, 2015 at 8:19 PM
    #38
    treejohnny
    treejohnny Well-Known Member
    2016 ACOR
    I will be doing the morimoto HID for the low beams. I am trying to figure out the best LED's for the high beams. The LMZ put out 4500 lumens, the OPT7 put out 3500 lumens and the morimoto XB puts out 3000 lumens. I would imagine that not all are rated the same and maybe one performs better in our projector better?
    Sam, what are your thoughts of your LMZ's for your highs compared to the stock halogens?
  19. Nov 15, 2015 at 6:26 AM
    #39
    ToyFXR88
    ToyFXR88 [OP] Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    I went with some starnill LED bulbs off Amazon, rated at 3300 lumens for my high beams. They were $66. A friend of mine owns his own performance car shop and just so happens to be a distributer of morimoto hid kits so I ordered one from him for $125. What price are others paying for the kit?
  20. Nov 15, 2015 at 8:58 AM
    #40
    ericsan777
    Eric
