Led headlight bulbs
Discussion in '1st Gen. Tacomas (1995-2004)' started by skidrow, Dec 24, 2017.
  1. Dec 24, 2017 at 6:53 PM
    skidrow
    skidrow [OP] Well-Known Member
    robert
    2002 double cab 4x4
    Bilstine adjustable 3" front--add leaf rear--skid row plates +
    Merry christmas guys!!! We ive searched all over and am not finding a very good answer i want to put in some led headlight bulbs due to lower amp and brighter output but im seeing people having alot of problems getting certain brands to fit with the battery and air box.... does anyone have a specific brand and or part number that will fit without any mods ?? Thanks and marry christmas guys!!!
    OneWheelPeel likes this.
  2. Dec 24, 2017 at 7:18 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  3. Dec 24, 2017 at 8:02 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    just don't get ones with large heatsink/fans on them, otherwise they will fit like normal bulbs
    I had a set from VLED and they fit fine between the battery. were a bitch to get in due to the attached heatsink but managed
    light "output" will not be any better than halogen (sometimes worse), they just look whiter.
  4. Dec 24, 2017 at 9:02 PM
    skidrow
    robert
    2002 double cab 4x4
    Ok thank you maybe i should just try new headlight housings they are original.....
  5. Dec 24, 2017 at 9:22 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah if they are "yellowed" then it decreases/diffuses the light output (think lamp shade vs open bulb). clean/clear front lenses let the best light out. you could also go for higher output bulbs but would need to read up on changing out the connectors to handle the wattage increase.
    2BeersPlease likes this.
  6. Dec 24, 2017 at 9:54 PM
    2BeersPlease
    2BeersPlease Well-Known Member
  7. Dec 24, 2017 at 10:30 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    It's not a good idea to run led's in a reflector housing, as the light will scatter and blind other drivers. You'd be better off getting nice halogen bulbs, or doing the ultimate headlight upgrade like mentioned above. Or if you really want led's, do a projector retrofit.
    Merry Christmas!
  8. Dec 24, 2017 at 10:34 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    ..Here's one link - https://headlightrevolution.com/headlights/headlight-bulb-upgrades/led-headlight-bulbs/
  9. Dec 25, 2017 at 6:40 PM
    skidrow
    robert
    2002 double cab 4x4
    Thanks for all the great info guys!! yea i guess i was just hoping for that cheap simple fix... but i guess ill have to pull the arb bumper back a bit and replace the housings and just do it proper
  10. Dec 26, 2017 at 8:35 AM
    Slickster
    Slickster greentaco
    2002 pre
  11. Dec 26, 2017 at 10:21 AM
    skidrow
    robert
    2002 double cab 4x4
    Have you had anyone flashing their highbeams at you ? Some people are saying we cant use these with our housing?? I just dont want to be that dick that everyone wants to shoot lol
  12. Dec 26, 2017 at 10:29 AM
    Slickster
    Slickster greentaco
    2002 pre
    actually you can adjust the bulb so that does not happen. also i did do a couple coats of plastidip smoke on the lens.
  13. Dec 26, 2017 at 11:36 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Oh no not this led nightmare again! They really arent meant for our housings regardless, unless you buy the correct housings. Theres a thread on here about this and many use Osram german 60+watt bulbs with upgraded harnesses for more light output than the leds that just scatter light every where thats not needed.
    03 NIGHT TACO likes this.
