Led Headlight Bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsage17, Jan 22, 2018.
  1. Jan 22, 2018 at 6:35 AM
    dsage17
    dsage17 [OP] Active Member
    Drew
    2005 Double Cab Prerunner
    2" level with KO2s
    What is the best "plug and play" option for second gen led headlight bulbs? I can't seem to find a go to choice in all of my google searches
  2. Jan 22, 2018 at 6:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Norton, Sig45, inwood customs and 2 others like this.
  3. Jan 22, 2018 at 7:08 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Norton, Sig45 and inwood customs like this.
  4. Jan 22, 2018 at 7:59 AM
    MountainMaker
    MountainMaker Well-Known Member
    Dan
    Castle Rock
    2005 Tacoma DCSB
    Headgasket and frame replacement
    I am a big fan of these guys, Cyclops Adventure Sports, I have their bulbs in my motorcycle and they have been steller for 15,000+ miles! They just released bulbs that have a "shield" for low beams.
  5. Jan 22, 2018 at 8:30 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’m removing mine for ultimate headlight upgrade but I went with briteassleds.com they are nice an have a cutoff not blinding to other drivers.
    Norton and crashnburn80 like this.
  6. Jan 22, 2018 at 8:46 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Then why are you removing them?
  7. Jan 22, 2018 at 9:01 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go with the 85/80w Hypers for best low beam performance.
    Maybe because a high powered halogen upgrade will significantly out perform an LED retrofit “upgrade”. The halogen optics are completely wrong for LED and will result in reduced overall performance.
  8. Jan 22, 2018 at 9:04 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    MattCowsmasher likes this.
  9. Jan 22, 2018 at 9:05 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Not gonna lie I swear I hear the whine of the fans on bulb with radio off driving me crazy.
  10. Jan 22, 2018 at 9:07 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Yes sir will do an you nailed it about halogen performance is another reason.
  11. Jan 22, 2018 at 9:10 AM
    vtdog
    vtdog Well-Known Member
    NH
    I looked at all the options for headlight replacement about 6 months ago and ended up just getting an OEM set on the web for about $20 bucks. Changing to LED/HID was just simply too much trouble for little gain. The original bulbs lasted 7 years and were fine. In addition to the cost for LED I recently found out that "cheap" LED sets can also interfere with radio reception. Basically it came down to cost and convenience (it took less than 5 min to change out the bulb set too). Big boy rules apply so you can do what you want.
    TAC1 and MattCowsmasher like this.
  12. Jan 22, 2018 at 9:15 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is due to EMI (Electromagnetic Interferance) which can manifest itself in a number of ways, static over the radio is most common. It can also interfere with CB radio/short wave radio communication. Some do it, some don’t. HIDs can do the same thing.
    Norton, Key-Rei and MattCowsmasher like this.
  13. Jan 22, 2018 at 9:16 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'm very satisfied with my H4 LED bulbs from SoCalMotoGear.com, I bought them as the GL1500 kit, they're drop in replacements, have a sharp cut off, don't scatter the light, run very cool, and are completely fanless. The use an aluminium coated copper ribbon for heat dissipation and they work quote well.
    The osram IR halogen bulbs are more powerful but I much prefer the cool 5000k colour of LED's. Plus I've seen too many stock headlamp assemblys bubble and melt just from the weaker stock halogens so the lower the temperature inside the housing the better IMHO.
    And besides, if I REALLY need more light I can put those IR Halogens to shame...
    :luvya:50" Rigid Hyperspot.:luvya:
  14. Jan 22, 2018 at 6:31 PM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Key-Rei[QUOTED] likes this.
