LED headlight comparison
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MannyS, Oct 13, 2015.
  1. Oct 15, 2015 at 9:19 AM
    #81
    atrouth
    atrouth Well-Known Member
    Anthony
    2016 MGM Tacoma TRD Sport DCLB 4x4
    I just bought the headlights for now. Gonna use my HID kit from my 2nd gen in either my fogs or high beams. Havent decided which yet
  2. Oct 15, 2015 at 9:30 AM
    #82
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Interesting that you say that, because when my friends and I were broke we were using DDM and they all went out within 6-12 months and DDM wasn't willing to honor their warranty. They didn't directly say it but after multiple attempts at trying and getting no response we gave up.
  3. Oct 15, 2015 at 9:42 AM
    #83
    atrouth
    Anthony
    Sooner or later I want to upgrade the fogs and maybe the highbeams. Im not sure HID high beams would be good for using as passing lights so Im on the fence about that. May just put my HID kit into my fogs since they can be used without headlights now and the wide angle ones are set up for a 55w bulb
    0uTkAsT[QUOTED] likes this.
  4. Oct 15, 2015 at 9:58 AM
    #84
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Weird. I have used their HID kits in almost all of my vehicles and only had 1 issue with my 2011 Mazdaspeed 3 where the lights got a green glow after about 9 months of use. I took them down to their HB location and they turned them on and saw the green glow and replaced them right on the spot.
    2008 Silverado
    2010 HHR
    2011 Mazdaspeed 3
    2013 Camry
    also have them in friends vehicles over roughly 2 years now
    2005 Accord
    2011 Mazda 3
    2014 Accord
    and no problems. I guess its just the luck of the draw with them.
  5. Oct 15, 2015 at 10:27 AM
    #85
    DMBFan37
    DMBFan37 Well-Known Member
    I think I want to do the fogs first because they look like shit. Does anyone know what temperature is closest to the stock DTRL? 6000K??
  6. Oct 15, 2015 at 10:30 AM
    #86
    atrouth
    Anthony
    Probably. Im sure 5000k or 6000k will look good either way
  7. Oct 15, 2015 at 12:33 PM
    #87
    DRJ1014
    CA
    I chose these for the fogs.
    http://www.amazon.com/gp/product/B00SZK26T0?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
    I put them in my GFs camry as well
    Pics here: https://www.tacomaworld.com/threads...jector-headlights.391832/page-5#post-10899500
    They look to the very similar in color to the LED DTRL
  8. Oct 15, 2015 at 1:41 PM
    #88
    joemartines
    joemartines New Member
    Joe
    2016 TACOMA TRD-OFF ROAD 4x4
    which of the two is better, LED or HID? And also which color temp would match the LED DRL?
  9. Oct 15, 2015 at 2:10 PM
    #89
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Depends on who you talk to and the application. HID may be better in a projector housing unless the projector is specifically made with LED. LED has longevity and takes very little power to operate. 5000 -6000 is bright white. Any higher and you start going blue until you reach purple. From Manny's test, the LED showed light dispersement covering a large area but the Halogen bulb actually had farther concentrated reach so there may be some give and takes between the two. I cannot comment on HID but since it closely resembles the Halogen i would say it will have a drastically farther reach thatn Halogen in the projectors.
  10. Oct 15, 2015 at 3:25 PM
    #90
    joemartines
    Joe
    Cool, thanks for explaining! Now could I use the same led dome light on the 3rd gen from the 2nd gen?
  11. Oct 15, 2015 at 3:53 PM
    #91
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    The HID will throw its light similar to the Halogen. The LED technology can't make the light emit from one source so it's harder to know if the LED will project correctly in the housing
  12. Oct 15, 2015 at 3:57 PM
    #92
    DRJ1014
    CA
    LED headlights while they are nice, don't give you as good of a direction of light as halogen or HIDs will in a single projector housing or reflector housing. If you notice on vehicles that come with LED lights standard or as an option, they will have multiple projector housings so they can control where the light is being projected to give you the same direction of light as say a halogen or HID.
  13. Oct 15, 2015 at 4:15 PM
    #93
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    They will be fine. The ballasts get power straight from the battery. The extra heat is negligible. Been running 50w in my other car's stock projectors for years.
  14. Oct 15, 2015 at 4:43 PM
    #94
    DRJ1014
    CA
    50w HIDs is so overkill. There is no need to go over 35w unless you are off roading with no light bars. 50w is just blinding to others.
  15. Oct 15, 2015 at 4:49 PM
    #95
    Aussiek2000
    2016 Offroad AC
    I aim down. Never been flashed by another driver
  16. Oct 15, 2015 at 4:56 PM
    #96
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    I would say 5000K, had LED DTRL's in a Rogue I was driving and the VLEDS 5000K Fog Bulbs matched perfectly.
  17. Oct 15, 2015 at 5:02 PM
    #97
    Z50king
    Eric
    Southern California
    Stock and loving it
    50 watts won't automatically make more heat than a halogen or be too hot for your projector. The increased wattage can be turned into light, like you want, and not into heat. All the wattage, energy, is turned into heat, sound, light, or light you can't see.
  18. Oct 15, 2015 at 6:30 PM
    #98
    MannyS
    MannyS [OP] Well-Known Member
    Republic of Texas
  19. Oct 15, 2015 at 6:42 PM
    #99
    8102
    British Columbia
  20. Oct 15, 2015 at 7:08 PM
    #100
    MannyS
    Republic of Texas
    I may opt for HIDs, but I hate all the wiring hassles and the multiple components that can fail.
