LED headlight comparison
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MannyS, Oct 13, 2015.
  1. Oct 15, 2015 at 7:11 PM
    #101
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    Check out the VLEDS kit, looks to be plug-N-play.
    Sucks the Leds don't work...
  2. Oct 15, 2015 at 8:19 PM
    #102
    DMBFan37
    DMBFan37 Well-Known Member
    Do you guys know what type of bulbs replace the license plate lights?
  3. Oct 15, 2015 at 8:49 PM
    #103
    MannyS
    MannyS [OP] Well-Known Member
    Republic of Texas
  4. Oct 15, 2015 at 8:58 PM
    #104
    DMBFan37
  5. Oct 15, 2015 at 10:31 PM
    #105
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  6. Oct 21, 2015 at 2:21 PM
    #106
    DMBFan37
    OPT7 H11 CREE Fogs and I like them a lot. Now I just need to find the headlights...
  7. Oct 21, 2015 at 4:19 PM
    #107
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Got my VLED's today. Probably wont be able to muck with them until this weekend. The fan housing is long and they may not fit but the mounts are adjustable so after I measure the Halogens I will set them up and see.
    0uTkAsT likes this.
